Technical OBDII plug
nauka
hi to all of you. I have a simple and stupid question. I tried first to search the forum, but I didn't find this info.
Where is precisely located the OBDII plug in our magnificent Panda? I have a 1.2l 60 HP gasoline version and I'm a very happy owner.:)
thanks a lot in advance
To the right of the steering wheel ,and down below the air vent you will see a flap undo the 2 screws at the bottom and remove .
Behind there, your OBD11 socket is hiding.
Given the flag under 'nauka's avatar, I'd guess the car in question is left hand drive, so it will actually be under the panel to the left of the steering wheel (but I guess he worked that out ;))
Once that panel is off, the plug is near the panel of fuses (in my instruction book this is shown as 'G' on the picture of the fuse box)
