Finally got around to servicing our 100HP this morning.
Bought service kit on line from Fos performance (very good to deal with) if any ones interested the links at bottom of page to copy and paste .
NGK plugs and Fram air/oil/ and cabin filters . £43.00inc P&P.
Used Halfords 5W/40 Fully Synthetic Oil 5L £34.99.
Local Fiat dealer for sump plug washer 85p.
The cabin filter is a bit awkward due to the steering column in the way,but bending it slightly and carefully slides in and cover clips back.
Did notice there was screw holes but no screws on the cabin filter cover.
Next was the Air filter, 3 bolts and a large clip + a small hose clip at rear of air box hold it onto the top of the engine.
once its off,6 small bolts (3 on top 3 on the bottom)hold air filter in the case.
Spark plugs are way down inside the engine ,but once the plug connector unit is removed (4 bolts +1 holding the cam sensor + 1 holding the unit to the engine) they are easy to replace, just make sure you keep the area around the plug holes clean.
I Found cleaning and wiping around the rubber bungs at the top of each plug connector with WD40 they went back down the plug holes with no problem.
Oil Change is a slight pain ,you need to remove the engine tray first 5 bolts and 2 torx screws.
Once tray is removed you can access the oil filter ,which is side ways fitted at front of engine , I used a strap wrench to remove filter as its very tight to engine and very hot.
Biggest worry for me ,was the dreaded sump plug that a few of you on here have had a problem with.
The sump case itself looks as if its made from some sort of alloy or aluminum.
Reminds me of the old BMC mini sumps.
This being a very soft metal ,you do need to be a bit more careful than with a pressed steal sump.
but all is required is when undoing the 13mm plug (17mm Socket is needed)is a sharp tap to the socket bar, don't pull hard on the socket bar this puts pressure on the soft threads.
Thoroughly clean the plug and sump thread (after all oil as drained away) and always, and I mean always ,use a new washer.
Replacing the plug is easy,start the thread lightly by hand ,any resistance at all and you will need to restart the thread again. once its going keep threading by hand until its tight to sump body.All is then needed is a light nip tightening with the socket.
Never over tighten, this pulls the threads down towards the plug,and the next time you change the oil , you will indeed strip the threads.
I think just under 3 liters of oil brings the level just above half way up dipstick.but I
always check the following day .
Thanks to all for your help,and I hope this will help you to service your cars yourselves.
One last thing ,when I was picking up sump washer from Fiat Dealer,
I asked how much to reset the service counter .
That will be £36.00 + vat sir
when I got back up off the floor ,I said I don't want to buy the reset machine,just want the counter reset.
that's the going rate sir.
can any one beat that ?.
Here's service kit link
http://cgi.ebay.co.uk/SERVICE-KIT-NEW-FIAT-PANDA-1-4-16V-FRAM-FILTERS-PLUGS_W0QQitemZ370343415579QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item563a300f1b
