Old 14-01-2010   #1
Wiper blades screen cover
My Panda 1.2 Dynamic is due for it's first service. The drivers side windscreen wiper blade travels too far, going off the glass and onto the rubber and paintwork. Is this normal for the Panda or should I mention it to the garage? Is it possible to adjust the amount of travel of the wiper arm?
steve101 is offline Reply With Quote Quote
Old 14-01-2010   #2
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Re: Wiper blades screen cover
Mention it
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Qubo Dynamic Dualogic WAV & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 15-01-2010   #3
Worth mentioning - but the size of the 'arc' the wiper sweeps across is not adjustable.
However, it may be that the wiper arms are not set correctly (ie the arms are fitted incorrectly onto the spindles that protrude from the trim panel below the screen). With the wipers turned off and parked at the bottom of the screen, there are a small black marker dots on the glass (they have a ring of clear glass around them and are in the black section at the bottom of the screen) that far end ends of the wiper should line up with and just sit on. Also, the driver's side blade should sit parallel to the bonnet. If it is fitted too 'high' up the screen to start with, then it will sweep past the side edge of the screen at the top end of the sweep. This starting/parking position can be altered by loosening the nut securing the wiper spindle, pulling the arm off the 'splines' of the spindle, refitting further round and retightening the nut.
Pete
2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
(T) Fitting aero\flat wiper blades on the rear wiper arm. Mk2 3dr. Is that possible? Caveman Punto (Mk2/2b) 0 21-02-2009 15:59
(G) Wiper blades Jane Wrightson Grande Punto 16 14-01-2009 09:51
(G) GP wiper blades fenton_jd Grande Punto 4 23-06-2008 11:42
(G) Wiper Blades altria Punto (Mk2/2b) 4 21-12-2007 13:11
(G) Wiper blades Boanerges Panda 7 05-11-2005 19:35
