little-blue-chichi
I feel something expensive coming on..... I've had no problems at all with the gearbox on my 2005 Panda Eleganza until a couple of weeks ago. To begin with very occasionaly when I started the car the gearbox indicator would go straight from neutral into first and not change into reverse when I moved the lever. Then the same happened the other way - sometimes it would not change from reverse into first. This is becoming more frequent and can only be dealt with by turning off and startig again. Also it sometimes flashes up that manual option is not available ( which it isn't when this happens) Any idea what this can be anyone? and any idea if it is likely to decimate my Chritmas fund? Higgle has done 39000 miles now. Thanks in anticipation.....
