Greetings all
When I start the engine on my little 4x4 I can hear water gurgling/rushing somewhere -- I presume in the plumbing to the heater radiator in the car. It quickly stops. The heater is working OK and the water level is fine in the header tank (mine is on the side of the radiator, and is at tlhe same level it's always been). I can sometimes hear it after sitting with the engine idling too, such as at traffic lights, when pulling away again.
Two questions: I presume there's air in the system, but how do I get it out. I can see there's a bleed screw on the heater hose, but that is higher up than the level in the expansion tank, so surely opening that will let air in, not out. And second, how did air get in? Is this a sign of failing water pump perhaps?
Any ideas out there?
Pete
Pete
