i would add that it depends on the car and gearbox setup you have. With my previous Panda 1.2 I would always go through the gears on up and down shifts as it was a long geared 5 speed box and with less torque so jumping a gear would curtail progress too much. On downchanges the skinnier tyres made it more prone to lock up if missing out a gear when downshifting although admittedly I was a beginner driver so my technique wasn't as polished back then either.
In the work Galaxy diesel, block shifting downchanges are essential to get the thing slowed down as the 6 speed is really long so you have to go from 6th to 3rd before you even notice any engine braking.
As the 100hp is a close ratio box you can usually jump a gear without a problem (I hardly ever use 5th for that reason)
