Copplemeister
- Mar 21, 2009
- 5
- 2
Hi all,
I have a light green 1.1 Active Fiat Panda (very fun to drive)
Heres the story what happend.... a few months ago i removed the drivers side door panel. I took the 4 or 5 screws out and pulled the grey door panel off to view the standard factory car speakers because i was thinking of changing them with aftermarket ones. I looked and put everything back...all worked.. nice and dandy..
NOW all of a sudden im having trouble with the locks! Car is central locking by the way, but not via remote.
Heres exactly what happens....
I simply put my key into the drivers side and turn... opens all door locks...great... BUT when i open the driver door - straight away for some reason the other 3 doors lock, unlock, lock. again. annoying!
Then, when i get in and close the driver door, it repeats the whole proccess again! unlocks, locks, unlocks... couple cycles then stops in either position. all the while the drivers door lock does not do the same.
Also, i have trouble trying to successfully lock all doors and safely walk away! ok thats expected, but its really annoying and need to fix it. The doors also seem to try lock themselves (expcept drivers) while im driving!
Not good. Im going to go work on it now. Any suggestions/ideas whats come loose and gone wrong?? i made sure the detail below was secure in its place, see picture>>>> again I HAVE made sure the handle to lock mechanism below IS secured in its seating... but im still having problems.
Copple
Copple
