Old 19-05-2009   #1
Thumbs down Water in passenger footwell 100hp
Hello,
Have any other 100hp owners experienced water ingress on their cars? Recently we had some very heavy rain and I noticed that the passenger floor mat was completely water logged. Looking underneath the mat the carpet was also extremely wet (I can get water bubbles out of it by pressing it with my finger).
I've tried to soak up as much of the water as I can with towels and I've been driving the car on max heat to the feet to try and dry it out. Still very damp though.
It looks like the water has come in under the carpet but was enough volume to soak the mat as well.
Anyone else seen this before?
namistai is offline Reply With Quote Quote
Old 19-05-2009   #2
Embrace depreciation...
Schwenck's Avatar
Schwenck has donated!
Re: Water in passenger footwell 100hp
I'm sure there've been a couple of posts about this before; some door seals can be perfect except in a one-in-a-hundred combination of wind direction, strength and rainfall. I guess you've discounted a heater matrix leak?
Circumstance means I'm currently outside the FIAT family, but you never know...
http://www.fiatforum.com/signaturepics/sigpic4009_23.gif
Schwenck is offline Reply With Quote Quote
Old 19-05-2009   #3
Have you had anything wired through the bulkhead to the battery? Sometimes the installers don't get everything back where it needs to be when they remove the scuttle panels etc which can lead to a leak.
Or have you had a windscreen? These can leak quite easily if not installed correctly.
Ben
BenP is offline Reply With Quote Quote
Old 20-05-2009   #4
Hi Guys,
Thanks for the replies - I think Schwenk has hit the nail on the end. Looks like I was just really unlucky with the strength of rain/windspeed/position of car variables! Doh!
It's nearly dry now - I reckon another run home today with a blast of heat should get it completely dry.
Old 20-05-2009   #5
Worth also pulling up the carpet and making sure it's dry underneath - when the Fabia's back door seals leaked I dried out the carpet and took it a friend who worked at a VAG dealership to work out what the problem was. He said it was a common problem and lifted up the carpet to reveal that I hadn't quite drived it all out as there was a few inches of sodden foam underneath the carpet.
Chris
Holding up the traffic in a little Italian......... :D
ScoobyChris is offline Reply With Quote Quote
Old 20-05-2009   #6
Isn't there a classic problem on Puntos where the pollen filter arrangement is hard to reseat and then allows water into the cabin? Is the Panda the same?
It would have to be a massive wave to get that much water in through a 'freak' incident. Check the door seal is seated fully.
Current fleet:
2007 Panda 100HP - Red
2006 Golf Gti - Tornado Red
2004 TVR T350 - Red Glow Pearlescent
Trefor is offline Reply With Quote Quote
(T) wet passenger footwell/running water sound! kaosNW Bravo / Brava 14 14-01-2009 12:43
(G) lots of water in passenger footwell f*ckedfiat Punto (Mk2/2b) 3 20-08-2008 23:57
(G) water in passenger footwell!! fastkab Punto (Mk2/2b) 4 01-04-2008 01:26
(T) Help! Mk1 98. Water leaking in passenger footwell Gezi Punto (Mk1) 14 19-05-2007 23:37
(T) water leak in passenger footwell blackpool_uk Punto (Mk2/2b) 9 15-12-2004 22:07
