regandavies
Does any one know how to locate and identify these two items on a Fiat Panda 16 valve multijet?
Thank you!
Thank you!
EGR on a 1.3? Nightmare!
Did you get there "from above"?
can you post a pic? are they coolant hoses or are they from an intercooler (?)
I'm familiar with system on other cars and could probably work things out/where the valve is from a photo.
but hopefully someone professional will come along...
Might also be worth seeing if the flat spot goes with the solenoid switch plug out, disabling the system. This might raise an engine light, which will exytinguish when re-plugged, probably...
