General Climate Control Issue
Portsmouth
Hey all. Got a bit of an issue with the climate control in my 100HP. I'll be reaching 12k miles soon so I'll be booking it in for a service and it'll get seen to then, but I'm interested to see if anybody else has had a similar problem. The selector for directing the air is bust. You can select them - they light up and stuff. But the actual mechanism is stuck on "feet". Which is quite annoying! Anyone else heard of this before?
Mine has just developed this problem this morning!!
Did you manage to get it fixed under warranty at the dealer?
Maybe the climate control has an issue with your feet.
Have you tried spraying the inside of your trainers with air freshener.
Pandas are very sensitive to odours, you know.
Arrrhh, but mine is stuck on the windscreen!!
I have just checked all fuses, bonnet and under wheel, and all ok. Looks like a trip to the dealer then...
First problem with the car after 18months, 12k. Dont let me down fiat...:mad:
8 months, 8000 miles - no problems, working very well in this weekend's heat.
Not experienced this myself, but on VAG cars it can be down to "sticky flaps" which just need to be recalibrated by a dealer using the diagnostics equipment. Hopefully it's something nice and easy on the Fiat :D
Chris
Turned out to be the actuators... replaced under warranty.
Everythings cool again!...
