My driver side window seems to be playing up....
Can anyone confirm which of these operations are working correctly?
From fully closed:
Press quickly and release....Window moves down a fraction and stops
Press for longer........Window opens fully
From partially closed:
Press quickly and release....Window moves up a fraction and stops
Press for longer........Window closes
I'm sure it used to close fully from fully open with the longer button press....?
From fully open:
Press quickly and release....Window closes a fraction and stops
Press for longer........Window closes about 5cm (2") and stops (you can hear the switch / relay click)
Press again (longer press)....Window closes fully
The operation in Red is the one that seems to have changed
Thanks!
From fully closed:
From fully open:
Thanks!
