whats that? an airedale? very cute
Well Spotted, an Airedale. Kinda rare these days?? She's gonna be 9 this year.
you doing all the welding yourself then? What type?
I was wondering what you were up too....i'm very interested in the progress. But i can imagine stripping the sealant is a bit like watching paint dry
Kristian
looking outside today at the weather,
good luck Nigel
I presume MiG welding strips the galvanising or you grind the galvanised layer off first. So do you get the shell re-galvanised or just paint it?Yes mate, the whole car is DIY. I try to do everything myself including design, fabrication and Machining. The seam welding will be done with a MIG.
I'm gonna "Grind" away the Galv in the areas I need to weld. Not quite sure how yet though??? I think a flap wheel on a grinder will be too aggressive? Maybe a sanding disc on a Dremel will do it.
I don't suppose anyone knows of a chemical that removes Galv??
i would have said a flap wheel of some type - maybe ask here:
http://www.ukwelder.com/forum/index.php?showtopic=1730
Nice. keep the pics comingAs promised, some pics of the frames that'll hold the body in the air, in any position for the seam welding and underseal removal.
Basically, these frames will sit in two engine stand like frames that will allow the body to swivel.
I've also posted a couple of pics of the car on castors, so it can be rolled in and out of the garage. There's also one of a wheel put in the rear arch. Possibly the lowest Panda in the country??
Come on nigel, I busy waiting for pics and updates
Kristian
