On the motorway today my speedo started to swing wildly.
The Rev counter was rock solid and the engine sounded fine. It was responsive to the throttle.
Then the speedo started to drop to zero and the radio would start to die out.
I started to get power steering error messages on the dash and the trip computer died only to normal operation again
This problem continued regularly for the remainder of the journey.
I suspected a dodgy battery or alternator.
When I got home I whipped out my multimeter and measured 12.3 volts across the terminals of the battery when the engine was stopped. I measured 13.4 volts when the engine was started. From this I assume the battery is OK.
I still suspect alternator problems.
I may have access to a generic handheld EODB diagnostic tool. Will this be of any use to me.
Any suggestions please.
The car is a 1.2 litre Panda Eleganza. 57 Reg with 2000 miles on the clock.
