General panda 4 by 4 turbo it's here
The Sultan
Bravo 1.8 HLX FTW
lake windermere east edge
it's here
i drove one today fiat dropped it off at my work and 3 others according to the particular car transporter driver
it has the multijet 1.3 not sure if it's 75 or 90 i'm guessing 75 as it will fall into the 35 quid tax bracket
blue and me
crazy plastic bits all over like on the panda cross
nice 15" wheels
air con
and e.l.d that stands for electronic locking diffs aparently but it does not have any locking diffs it simply uses the abs breaks the wheels that are spinning to aid traction to wheels that have grip
basically the opposite of what a normal diff does powers the wheels that are sinning so considering the normal panda 4 by 4 goes anywhere this thing will be unstoppable
has a button marked eld to turn the system off and revert back to normal abs so you can have some drifting fun i assume
so it looks like at last you can get hold of a 4 by 4 turbo diesel panda in the uk
salesman say it will go for around £13.000
Sounds interesting, although 13k seems a bit steep! Notice you said it has Blue and Me - is that the proper one (as found in the Grande Punto) or the primitive "Bluetooth" one that's found in the other Pandas?
Oh, and what was it like to drive? :p
Chris
You said 'plastic bits like the Cross' -- so is it the Cross?
erm probably i never thought to ask our salesman what it was actually called
i assume the cross is a diesel 4 wheel drive in other countries so yea it probably is a cross
i thought the cross was a normal 1.2 4 wheel drive with crazy plastic bits
well i only saw steering controls for the phone so it may just be bluetooth for the phone
il try get some pictures and more information tomorrow
yes round headlamps
there pretty clever actually there split in the middle dip at the top main at the bottom so brighter than normal lights with h4 bulbs as they have 4 bulbs totalling more than 200watts
Was it like this?
Bo**ocks if I had only waited 6 months :bang::bang:
Will def have one when it's time to change over :worship:
BTW the cross does have electronic locking diffs so is it possible the seles bloke didn't know all of the answers?
Sorry, but the Panda Cross's 'ELD' does not lock the diff, despite its name -- it merely applies the brake to a spinning wheel (rear only). This is well covered in other threads and well-described on various websites.
[such as here: http://www.italiaspeed.com/new_models/2005/fiat/panda_cross/mechanicals.html -- half way down left side]
But, by applying the brake to lock a spinning rear wheel, the drive is transferred to the other rear wheel, creating the effect of locking the diff. This is why Fiat showed it off using offset ramps [see here: http://www.youtube.com/watch?v=3MCdm4vMwwM], so that there was always a rear wheel in the air but the car carried on driving.
Since all this is done using (1) the rotational sensors and (2) the hydraulic pump of the ABS system, I am sure there must be a way of retro-fitting it (maybe even something as simple as programming it in) to a 'normal' 4x4 Panda (as I have also commented on before in previous posts). Now the Cross is here in the UK, I may be able to extract the answer from a UK dealer as to how this might be done.
So do you guys think I am correct in assuming if Fiat have engineered the Cross for RHD, they will also have done the same for the regular Fiat 4x4 Panda? That would be the car I was interested in.:)
