Hi, could someone please tell me what pressure the tyres should be. my manual tells me in Bars. but i need to know properly e.g 30. thank you
Thx but when i go to check my tyres myself at morrisons ya have to put numbers in e.g 30 .
The other problem with using garage forecourt pressure gauges and pumps is that the tyre pressures should be measured cold. Therefore if you have driven more than about a mile to the garage the tyres are warm and will end up underinflated.
Investing in a 12v electric pump and a reliable pressure gauge is well worth it.
The advantage of doing long shifts at a petrol station, do tyre check when my shift has finished with nice cold tyres
I also use a digital pressure reader because I to don't trust the compressors read out as far as I can throw one
Jon.
Digital tyre pressure gauge from Halfrauds £5...
Think mine was £4 from wolly's.
29 & 26 every time.Hi, could someone please tell me what pressure the tyres should be. my manual tells me in Bars. but i need to know properly e.g 30. thank you
