It's even a different ecu to the 500 1.4, go figure!
i dont understand why the 100hp has this ecu, i understand why it on the gp because that has that actuator to block of one inlet port and varibale cam timming stuff. but why is it on a hp, didnt see no weired stuff on stus engine
i still thinking you could stick a punto mk2b 1.4 ecu (new) into the 100hp and map that
29pgc10 said:... or put sometihing like Perfect Power/Dastek piggy back and be over with it. That's the plan... Now this Gazzella Racing crowd, how reliable are they really? I can't jump in a car and go over to demand my stuff of money, you know...
Martin
PS.: the white panda awaits in anticipation...
The ECU is linked to teh chassis on the Panda isn't it? So you can't just plonk another ECU from another car in it.
29PGC10: I'll wager your fuelling will start to go off at or past part 3.
CharlieD - Yes, but it's not what you would call cheap. It has to be either spliced into the loom or a special loom made up, then there's the price of the piggyback unit itself and the dyno time to set it all up. Someone is offering a 'group buy' if morre than 10 HP owners are interested - looking in the region of £500 each.
Was the 75 horses at the wheels or at the flywheel power?
Chris
At the hubs. Dynapack is a chassis dyno . One 'hangs' the car on it. Have look at www.dynapack.com
m.
