lanchester01
Hi All
Haven't posted in ages. Ever since my work blocked this site!
Anyway. I have a Panda 4X4. Now at 45k miles.
Tonight, traveling back from work, I lost power. Pulled over and the engine was idling smoothly but when I pressed the throttle down the revs only went up a couple of hundered revs even with my foot to the boards. The ECU warning light was on.
Being a computer support analyst, I switched the ignition off and back on again. The warning light was still on but the engine reved OK. I set off again. A mile or so later it went into limp mode. I pulled over. Switched it off and back on again and it got me home running fine. Warning light still on.
This summer, while on holiday, the same thing happened. It just so happened that I was passing Inverness on the way to Applecross so I called in at the Fiat dealer there. They were very helpful and told me it was the throttle sensor. They cleaned it and cleaned up all the earths. It's been fine ever since.
I wonder if it's the same thing. When they said throttle sensor I wasn't sure if they meant the throttle pot, throttle position sensor or stepper motor though.
Looking though some other threads I see that disconnecting the battery will re-set the ECU.
Does anybody think this is a good idea or not?
It will have to go to my local dealer in Consett but I would really appreciate any thoughts anyone might have.
Many Thanks for reading
Tim
45K miles of happy pandering. A few issues but nothing I would blame our lovely pandy for.
Tim
