im Axle Specialists
Old 05-09-2021   #16
chris3234 has donated!
Re: Fiat Panda Pop 2012 oil problem
Quote Originally Posted by murphyv310 View Post
It's a C3 spec oil for the 1.2 fire engine not C2
True but c3/c2 is going to make very little difference so either will work just fine
chris3234 is offline Reply With Quote Quote
Old 05-09-2021   #17
KPat has donated!
Quote Originally Posted by jrkitching View Post
ECP's own brand, and generally regarded by those in the know as rubbish, it's also the wrong spec for the car (it should be a 5W40 C2).
I'm pretty certain Triple QX is a hydrocracked oil - google the difference between hydrocracked and PAO oil base stocks.
That said, the 1.2 FIRE isn't demanding regarding oil and it'll probably work just fine, providing it's changed regularly.
Most ordinary synthetic oils use around 50% group 3 severely hydrocracked base stock. And it is legal to call it synthetic. And whatever else is added is usually shrouded in secrecy. It could be PAO plus other chemical additives.
Only racing oils have large amounts of PAO.
KPat is offline Reply With Quote Quote
(T) 2012 Panda Pop rear disk conversion? MunchBunch Panda (2012+) 21 1 Week Ago 21:42
(G) fiat panda pop 2012 mariop1 Panda (2012+) 10 04-10-2020 10:48
(T) 2012 Fiat Panda POP Blower Resistor Johnnyg78 Panda (2012+) 9 04-08-2018 10:09
(T) 2012 Panda Pop 1.2 - Sticking clutch/stalling kendallmint Panda (2012+) 2 18-01-2017 17:08
