Old 28-08-2021   #1
Nutty about Pandas
The Panda Nut's Avatar
Trader Rating: 1
The Panda Nut has donated!
Brake discs
Does someone know if the Panda 2012 onwards 1.2 69HP brake discs are the same or different from the 2011 Panda 1.2 69HP. I know the pads are not the same. S4P have different part numbers. Thanks
Noop now known as Nooplebe (i.e. in the way wherever he goes) 🐼
The Panda Nut is offline Reply With Quote Quote
Old 29-08-2021   #2
Herts Hillhopper has donated!
Re: Brake discs
Front discs on the post 2012 cars are 257mm diameter. Pre-2012 they were 240mm.
Thanks The Panda Nut thanked for this post
2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the Thumbs up 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Old 30-08-2021   #3
Nutty about Pandas
Trader Rating: 1
Re: Brake discs
Quote Originally Posted by Herts Hillhopper View Post
Many thanks for this. Blueprint .com parts actually cheaper than S4P at just £26 the pair. (Pads £15) I will drop them on in a few weeks for the MOT. am still mighty impressed with the quality. Honing marks are quite beautiful.
Rather suspected the set I have unnecessarily just bought for the 169 were different. (your discs are quite worn and the pads down to 30% Sir. Actually the discs were still 11mm thick so virtually unworn, and pads at more like 60% remaining. Should have gone to Spec savers.
Old 30-08-2021   #4
Re: Brake discs
Iíve been pleasantly surprised at how long the discs and pads last on my 4x4 MJs. At 32k miles, just checked mine today and found still plenty of life in both. This carís predecessor also saw 40k plus before front pads needed changing. I am quite gentle with brakes and tyres, but even so, those on the Panda does seem to be quite long-lasting.
Old 02-09-2021   #5
chris3234 has donated!
Re: Brake discs
The light weight of the Panda probably helps a lot
chris3234 is offline Reply With Quote Quote
Old 02-09-2021   #6
Re: Brake discs
Quote Originally Posted by chris3234 View Post
Yes, I think it does
Perhaps unusually though, at least with the three 4x4s I've owned, the wear is pretty even front to rear (both brakes and tyres) - whereas other cars of mine (FWD) have all worn the front brakes and tyres at about twice the rate of the rears.
Old 02-09-2021   #7
Re: Brake discs
On my Panda i get even wear on the tyres as when the front tyres get down to about 4 - 4.5mm I switch them to the back & put the better hardly worn rear tyres on the front then replace all 4 tyres at the same time, I changed the original Fiat discs for Brembo at 24,700 miles just before the MOT as the discs felt slightly warped when braking & found quite a few comments on the forum about this problem on Panda's & 500's so must be quite common, also put Brembo pads in & 4 new Avon ZT7 tyres on at the same time. My old Bravo 1.2 16v(known as the green pig) that I had when I was 18-19 years old used to eat tyres like they were going out of fashion.
FiatMatt94 is offline Reply With Quote Quote
Old 3 Weeks Ago   #8
Re: Brake discs
I need to replace the front discs and pads on my wee yellow beastie (4x4 TwinAir Cross) before its MOT next month. (I'm going to let Mr Fiat do the rears... it's worth the £190 he's quoted to avoid the pain & misery.)
I've found these Brembo discs on the Autodoc website (which is a total pain to navigate) & at £20.02 each (vented, 257mm. coated), they're much cheaper than I can find them anywhere else, and much cheaper than Pagid, which would have been my go-to option.
Am I missing something? Are these the right ones?
https://www.autodoc.co.uk/brembo/1657001
Barchetta LE (no 2468), 1998, Silver with Red Hood/Leather, Hardtop, Wind-stop, Novitec SS Exhaust
Panda Cross Twinair, 15 Reg, in glorious Yellow
Talbot-Matra Murena 2.2 (Prep 142), 1983, Aquamarine
gar074 is offline Reply With Quote Quote
Old 3 Weeks Ago   #9
Re: Brake discs
It looks like Fiat made a bunch of changes to the Panda in 2015. It seems they changed the brake discs from vented to solid. The link below gives the changeover date as being 26/05/15 but I'd have an actual look at what you've got on your car before buying.
https://www.fiatworkshop.co.uk/parts...ke_Discs.shtml
My 2016 has solid discs and I used Apec DSK551 which I'd say are just as good as Brembo. I bought them from Aceparts on eBay: https://www.ebay.co.uk/itm/392064952236 That's showing for me as £26.91 for the pair with the code PURCHASE4LESS.
Slightly cheaper here at 2 for £25? https://www.ebay.co.uk/itm/324721355555
Failing that, here's Autodoc's solid Brembo options:
https://www.autodoc.co.uk/spares-sea...lier%5B1%5D=65
Jiffycom is offline Reply With Quote Quote
Old 3 Weeks Ago   #10
Re: Brake discs
Mine are vented
(G) Panda Multijet Diesel Brake Discs and Pads and Brake Fluid Change ytareh Panda 0 24-06-2014 00:39
(T) Brake Discs RowingLad87 Grande Punto 13 18-06-2014 23:11
(T) Brake discs! AllenLowe Punto (Mk1) 6 22-03-2011 17:53
(G) Brake Discs srgl99 Grande Punto 3 23-03-2010 19:07
