- May 10, 2010
- 2,669
- 797
This is interesting
A 500 rear axle that's thicker.
https://www.ebay.co.uk/itm/12399032...4e61b6ed4cb062f92c1d|ampid:PL_CLK|clp:2499338
"Product Notes: The engineers at IM Axle Specialists have redesigned this axle to fix the weak points in the OE axle design and the following features are now included with this axle. This is the ONLY Heavy Duty Axle available for this model in the market.
Metal spring pan is 0.5mm thicker than OE and coated to protect against corrosion
Thicker Anti Roll Bar than OE for increased resistance to cracking and snapping (many other sellers do not even have the standard OE thickness)
Pre-installed OE Quality Bushes"
They state the spring pans and anti roll bar are thicker.
Is the anti roll bar they mention the actually twist beam part?
