im Axle Specialists
Old 16-04-2021   #16
Herts Hillhopper has donated!
Re: Broken back axle AGAIN!
[deleted, because I was wrong ]
2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the Thumbs up 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Old 16-04-2021   #17
Pugglt Auld Jock has donated!
Quote Originally Posted by bimmer View Post
My Rumanian mate brought his van and welding gear to the middle of
nowhere.
Put a ratchet strap between the axle hubs to close the gap and a jack to align the two parts.
Plenty of sparks and it was done. Some anti corrosion black paint, wheel on.
IF this cracks again we are going to bridge the weld by 100mm each side with a 4mm x 25mm plate on the lower inner edge. We have a plan.
And why does the forum rotate every photo 90deg?
Now this REALLY interests me - a lot. Can you keep us updated on how the repair works out over time?
With the spring pans being such a known weakness and having my own welding gear I've thought I might attempt a welded repair if Becky ever succumbs to the "rear axle gremlins". The reason I'm so interested is that the beam, I guess, must be more similar to a spring steel than a straight mild steel, and the problem this causes when you try to weld it with simple "DIY" type plant, is that it becomes very brittle around the weld, so I would expect it to crack again quite soon after repair.
I've got my fingers crossed for you.
Likes bimmer liked this post
Pugglt Auld Jock is offline Reply With Quote Quote
Old 16-04-2021   #18
Quote Originally Posted by Pugglt Auld Jock View Post
With the spring pans being such a known weakness...
Only when the drain holes in the bottom of them become blocked and salty water sits in them. They seem to get small stones in the holes very easily and mud then seals around these. A good jet from the hose now and again keeps these happy. Red circle shows one of them.
Thanks Pugglt Auld Jock thanked for this post
Old 16-04-2021   #19
nowhere.
Plenty of sparks and it was done. ...
You might get away with that there, but a UK MOT inspector should fail that without question!
Likes bimmer, murphyv310 liked this post
Old 16-04-2021   #20
KPat has donated!
Quote Originally Posted by Herts Hillhopper View Post
I've sprayed waxoyl in.
KPat is offline Reply With Quote Quote
Old 16-04-2021   #21
...And why does the forum rotate every photo 90deg?
Only the 'preview' thumbnails are rotated - click on them and they are correct when they open full size. It seems to do this will all images taken on an iPhone. Often if they are landscape (wide) photos, they appear here upside down!
Likes varesecrazy, bimmer liked this post
Old 16-04-2021   #22
Quote Originally Posted by KPat View Post
I nearly added in my message about the drain holes - 'beware spraying Waxoyl or similar into them, as this tends to clog the holes with a sticky residue which makes them block up even more easily'... but didn't
Old 16-04-2021   #23
No Fiat now unfortunately
murphyv310 has donated!
Spot on.
You can use waxoyl but make sure the holes are clear. I've been using Lanoguard, it's quite thin and doesn't seem to clog.
How well it stands up in time is another story that as yet I don't know.
Cheers Trevor
2M0GZQ
murphyv310 is offline Reply With Quote Quote
Old 17-04-2021   #24
Spain
Herts Hillhopper: Well that is the great unknown with the test requirement here. If I could be arsed I could trawl the Test manual for here but I'd rather leave it to the tester on the day in December.
bimmer is offline Reply With Quote Quote
Old 17-04-2021   #25
Hi.
I remember the beam in my lounge and when cleaning it up and waxoyling it how I thought it quite a little thin on the metal front. This one on the City cross is decidedly thicker, the mounts are the same and I would think it would still fit with sufficient clearance with the standard springs. If you are interested I can take more pictures and take measurements.
Cheers Trevor
2M0GZQ
Old 17-04-2021   #26
Quote Originally Posted by murphyv310 View Post
And that's why this is such a great forum.
Barchetta LE (no 2468), 1998, Silver with Red Hood/Leather, Hardtop, Wind-stop, Novitec SS Exhaust
Panda Cross Twinair, 15 Reg, in glorious Yellow
Talbot-Matra Murena 2.2 (Prep 142), 1983, Aquamarine
gar074 is offline Reply With Quote Quote
Old 18-04-2021   #27
Spain
murphyv310: Thanks for the offer but I will look out for any Pandas when I visit the scrappies, just to be nosey and ask how much they would want for one.
Old 18-04-2021   #28
Hi.
No problem. It's actually raining here so my plan was to take photos and measurements either tomorrow or Tuesday. I'll do it anyway in case anyone else wants the info.
Cheers Trevor
2M0GZQ
Old 18-04-2021   #29
Do all 2wd Pandas suffer this at some point?
2013 1200 POP
Leroypanda is offline Reply With Quote Quote
Old 18-04-2021   #30
Quote Originally Posted by Leroypanda View Post
I think Bimmer's is the only one ever seen on this forum, and that's been used on the less than perfect mountain roads of Malaga.
Likes Leroypanda liked this post
(T) Abarth V standard back axle DaveMcT 500 0 09-07-2018 16:49
(T) Back axle oldbaldy Panda 7 19-11-2014 16:23
(Tu) Supersprint vs. Novitec vs. Magneti marelli Axle back units mazenimad 500 5 09-11-2012 16:25
(G) Back Axle Markdapoppy Bravo / Brava 2 07-01-2011 13:58
(T) Putting the back of a Bravo on axle stands Adrian Bravo Bravo / Brava 1 21-10-2009 15:56
