Chriselectrics
Member
- Sep 23, 2015
- 150
- 94
Front Tyres Positive camber tire wear reasons?
I mean have you seen this and what suspension parts where worn?
Just swapped out the tyres. Old Front ones had this wear on them.
Outer-Edge Tread Wear
Tread wear on the outer edge of a tire is rare these days, but it does happen. Positive camber, caster and toe can lead to wear on the outer edge. If you see edge wear on one side, check the "thrust" and "setback?".
But, it should be noted, the leading cause of outer edge wear on modern vehicles is over-enthusiastic cornering.
Its 2014 pop with 82k on the clock still doing 54MPG...
So not too grubby...
