Hi Folks,
First post, hope you can help.
2017 Panda Pop, 19K miles.
I had a problem a year ago, sitting at idle, engine warm, revs rise to 1500rpm and EMl goes on, tells me no hill start, no ABS etc, although I don't have hill start. Fault code 0101
Anyway, I removed the clutch switch, taped it in the pedal up position, all was good, replaced the switch after a week or so, all good.
It's started doing exactly the same again, this time code 0101 and 0106. I checked the MAP, all good voltages, but I replaced it anyway, still the same, so I re fitted my old clutch switch, still taped in the pedal up position, no change, but this time only code 0101. put the plug back on the replaced clutch switch, still the same.
Switch engine off, restart, fine, for about 20 seconds, then same again 1500revs and warning lights EML too.
Could it possibly be yet another duff clutch switch?. Is there any way to check them?.
Any help gratefully received.
Thanks,
Alan.
Thanks,
Alan.
