Well, no vac leaks from the breather pipes, they are spotless, I reset the ECU, no difference, checked the manifold nuts, throttle body screws, all perfect..
I sprayed carb cleaner at or around all of the air connections I could see, even the manifold where it goes onto the head, no rise in revs.
There's not much left for me to check!. It's at the stage now where, when the engine is hot, it will last 10 seconds or less before the revs rise and the EML goes on, switch off, restart, and 10 secs or less and it's away again
I think the Idle control valve could well be the next thing to look at. But wouldn't there be a fault code showing up for the ICV?.
No easy two screws to hold it in though, a big plastic body held on with 6 clips, underneath which I assume the ICV lurks? . So if I remove the TB then the plasic clips, can I then access the ICV and clean it? Or is this the cover for the fly by wire actuating assembly?
Thanks for all the replies folks.
Alan.
Alan.
