Oil switch allegedly pig to get to. Need to find good independent Fiat specialist.
Need to find out what sort of guarantee you'd get on the work done if didn't cure it. 82k fair life for the Uniair to me. Could be 4 figure repair though. Not sure worth it.
Quick update for anyone interested!
Had the codes all checked and the only fault was "turbo air leak".
The mechanic then reset all the "oil service codes" apparently there are 3 of them.
He then took out the uniair oil filter (my request following advice on here- thanks!) it wasn't bad perhaps a little clogged on one side so he cleaned it off and reinstalled .
One of the air pipes was loose which may have accounted for the fault code so he tightened this up and sent me on my way.
So far so good but only done about 40 miles in it since this work so wouldn't expect a problem yet.
For those who asked- it has 82k miles oil changed anually (approx 12-15k miles most years) it's a 2014 car. I've had the DMF and clutch done already.
Still running on the 0/30 but I will change if it continues to through the odd hissy fit
Why use an oil your vehicle was built to use?
If you are trying to achive the MPG figures FIAT published..
Put an MJ sticker on it
Oil specs often change during many years of production for differing reasons. To cite some reasons I've read over the years are.
Excessive cam lobe wear..... Oil viscosity to high when cold or in winter so the winter spec is now applicable to all year use eg going from 15W40 to 5W40. Also have seen this to improve winter starting. Reducing viscosity to improve fuel consumption. Change of oil spec not viscosity to reduce timing chain wear and many others. These are in the main recommended for existing vehicles and in the past the dealer would ask for the handbook and put a sticker over the existing recommendation, not these days though as it costs a few coppers.
These changes were done without any material changes to the engine.
So, taking all this into account, as my TA has done over 110k miles, would it make sense to change the current spec of oil from the recommended 5/30 to something else more suited ? The engine runs like a dream, no smoke and pulls like a train!
I was left with thicker oil at higher mileage, but I got a lot of problems..
No.... what we are saying is to leave it at the older specification not to go thicker than the spec. If you go thicker than the spec in the TA you will land up with issues in the uniair module.
Ok so going thicker than the recommended 5/30 is not a good idea because of the uniair module but what about going thinner say 0/30 . Would this offer any benefits?
