Kims Panda
- Apr 12, 2019
- 8
- 3
Being provided with conflicting advice. The front Coupling to the Propshaft grease seal (boot!) has failed. Can you replace the Coupling (appears to be similar at the rear of the Propshaft as well) or do you have to replace the WHOLE Propshaft assembly including the front & rear couplings & centre bearing.
Also is it dangerous to continue driving with grease oozing out of the Coupling (will it eventually dry up & seeze up?)?:
