Old 01-10-2020   #1
fiat panda pop 2012
hi
please is there a guide how to bleed the coolant system? i can see any bleeder screw on the radiator .
thanks
mariop1 is offline Reply With Quote Quote
Old 01-10-2020   #2
chris3234 has donated!
Re: fiat panda pop 2012
What engine do you have?
chris3234 is online now Reply With Quote Quote
Old 01-10-2020   #3
varesecrazy has donated!
Quote Originally Posted by mariop1 View Post
hi
thanks
Look at the hoses going through the bulkhead
If its a 1242 petrol..
This is an opportunity to replace the thermostat
Old 02-10-2020   #4
Nutty about Pandas
The Panda Nut's Avatar
Trader Rating: 1
The Panda Nut has donated!
I have just done our two and have decided there are two tips. One is that this may need doing more than once. The other is a little pressure helps to displace the air. After lots of bleeding I decided to take the radiator cap off and blow into it while the bleed valve is open. It does have the advantage that you can see when the correct level is reached in the header bottle if rather a crude solution. The bleed screw is on top of a hose found looking down the right had side of the engine above the gear box and can be cracked off with a short screw driver if its a little tight. It had a little plastic wheel to allow for opening and closing by hand. I suspect the dealers have a radiator pressure pump. Don't allow any antifreeze into your mouth as it is poisonous. It worked for me. Haynes manual says there are no bleed screws on the radiator on the Panda. I always wash away coolant with clean water once the job s done to get rid of the sticky residue and smell.
Likes MaxHeadroom liked this post
Noop now known as Nooplebe (i.e. in the way wherever he goes) 🐼
The Panda Nut is offline Reply With Quote Quote
Old 03-10-2020   #5
hi
my panda is a pop 1.2 petrol year 2012.
please can see send me a guide step by step how you changed the coolant. which pipe to disconnect from the radiator. so there is only one bleed screw. i thought that there is one on the top right near the radiator cap because there is a metal bolt.
Old 03-10-2020   #6
No Fiat now unfortunately
murphyv310 has donated!
Don't forget the bleeder on the radiator too, often forgotten or not known about.
Cheers Trevor
2M0GZQ
murphyv310 is offline Reply With Quote Quote
Old 04-10-2020   #7
hi do you know where the bleeder on the radiotor is. i see a metal bolt on top left near the radiotor cap. is that the one?
thanks
Old 04-10-2020   #8
Once the rain stops I'll post up a photo for you.
Cheers Trevor
2M0GZQ
Old 04-10-2020   #9
Here is the bleed screw on the radiator. Also undo it when draining the system. When filling make sure you fill the radiator first and ideally mix the coolant first. Once a steady stream comes out of the radiator bleed with no bubbles then tighten it while it still is flowing, expect to loose some coolant. Then proceed to the top hose with the bleeder screw again keep adding coolant till it runs with no bubbles tighten the screw with coolant still running. Top up to maximum, run the engine till the fan runs which may take a while, then check level with the engine cold. Top up if necessary.
Cheers Trevor
2M0GZQ
Old 04-10-2020   #10
Hi.
Buy a suitable jubilee clip for the hose at the bottom of the radiator before you remove the hose from the lower part of the radiator. It's a good idea to replace the thermostat at the same time and get an alloy housing as well as the Fiat one isn't long lasting.
Cheers Trevor
2M0GZQ
Old 04-10-2020   #11
thanks
for all your help
(T) 2012 Fiat Panda POP Blower Resistor Johnnyg78 Panda (2012+) 9 04-08-2018 10:09
(T) 2012 Panda Pop rear disk conversion? MunchBunch Panda (2012+) 8 19-06-2017 10:39
(T) 2012 Panda Pop 1.2 - Sticking clutch/stalling kendallmint Panda (2012+) 2 18-01-2017 17:08
