steve gray
Member
- Aug 28, 2020
- 43
- 66
Looking for advice on what type of air con recharge kit to use to top up fiat panda easy 2013 and correct gas type any advice would be greatly appreciated
How do I check system pressure
Plug into OBD port
If the pressure is fine.. why are you regassing
If there is little pressure..get the vacuum test done
ATS didnt charge me when they pumped out the old fill..then discovered a leak on my old estate
They had a Groupon deal recently too £39
I seem to recall
Are you sure the pressure can be tested via OBD?
High pressure can be read via the obd port yes
When you turn the heat control right to blue it should be cool air even with the air con light off. If its hot when right to blue its a flap issue Not the air con.
