Bought my Panda 4x4 new late in 2018, however shortly after collecting it I noticed one of the rear calipers wasn't working as the disc was going rusty, which was fixed under warranty.
Fast forward and I've recently been getting an unusual old wheelbarrow type intermittent squeak particularly after descending a hill. Noticed when you press the brake pedal it stops and have since tried slightly applying the handbrake which also stops the squeak, so suspect its a rear brake issue.
Have taken it to the local dealer (not the supplying as I've since moved house) but they say its no longer a warranty issue, so they want to charge a packet to do a full service on the brakes; cars done less than 11k!!!
However I think its a fault with that rear caliper again not working correctly, so thinking I should try remove it from the disk myself and have a look, which I have the skills to do but I'd like to find a manual to give some guidance on torque settings and parts breakdown etc.
Anybody advise on where I might find such a manual?
