Technical Where is the Air con low pressure port?
Mads Gorm
Member
Hi
Where is the Air con ( AC ) low pressure port on Fiat Panda 2012+ 60Hk 0.9
Thanks in advance for any help
Hello,
On my 2015 TA it is between the engine and the bulkhead on the passenger side near the oil filter and the brake reservoir.
pic attached, the high side is behind the drivers side headlamp.
Hello,
Mine looks just like yours - have you tried filling it yourself?
Yes, topped mine up a few weeks ago, the only drama being my diagnostic reader doesn't talk to my car properly, so i can't see the pressure etc from the car.
just had to make do with the little gauge on the aircon topup handle.
Great - and thanks for the replies. What do you use to fill up with and as diagnostic reader?
I prefer to have as much info when I am doing stuff like this, if you have access to the diag info you can monitor the pressure and condenser temp etc before during and after.
This also gives you instant feedback if something odd happens.
Does anyone recommend a diag tool that can read detail like this for our pandas?
