Well I'm very glad your problem was fixed cheaply and you had good service.
The poster in Germany is interested in fixing his problem himself. Which is why he has asked for our technical help.
Hi DavidThx for all the contributions.
Herts Hillhopper: Sounds reasonable. Will record metrics during "flight" to see, wether and when the voltage goes up. Might corroborate your theory which reads sound enough.
As I only have a pc with Multiecuscan to do the recording, do you have a suggestion as to which ECU to observe?
And just to confirm: You are putting forward the proposition, that the "static" batterie test done in the garage is not telling the whole story - just to say the least. Did I get your idea?
Thx,
David
I don't know where to find wiring diagram.
Bernie may help.
jackwhoo: Might be well worth a try! Perhaps I can do this tomorrow. Then I will be in the mountains. Will charge the battery and engage the hills!
The drop to 11.9V is indeed intriguing. What is the root cause of this? It is the time the solenoids (ABS, Traction Control, Diff-Control) are engaging, the ABS pump spins off. But all of these devices do work when I actuate them via MultiEcuScan. OK, all of the 8 ABS valves run through an not further specified error condition. Perhaps I should check the voltage with a multimeter while actuating! Chances are that I eventuall down spikes will escape me without an osci - to which I have no access :-(
so far as I know, the voltage sensor on the battery itself is only there for the stop/start system — and decides the battery has sufficient charge to restart the engine if it auto-stops.Just an observation but at no point has anyone considered the power steering (PAS) as a source of the voltage drop while mobile. From rummaging under the dashboard the PAS certainly seems to have that potential given the diameter of the cables that connect it! Again, I don't have the knowledge to diagnose remotely but I would consider the function of the voltage regulator on the battery post.
The graph shows that the voltage didn’t drop below 12.6 volts during that journey, which I’d say shows that the alternator is working, and supplying a small amount of charge even when the engine is under load....
- Did change the battery a few days ago. Same make, same model as the original one.... how old is the battery, and what mileage (total km) has the car recorded? How is it used - small, short journeys or long runs? Every day or less frequently?...
