Technical The Consequences of Low Voltage....
Guildford
Folks,
As there are so many questions posted here regarding the cause of messages such as "Stop/Start Unavailable", Engine Management Lights and yellow Warning Triangles on the dash, I thought I'd share my experience from yesterday morning and my low voltage moment. Hopefully it proves all the theories mentioned previously and shows that it's a simple fix overall.
So, car had been sat for 2 weeks (2014 EU6 4x4 TA) going nowhere and having completed only very short journeys for essential shopping the previous fortnight before that. To compound matters, I also have a hard-wired IQ inductive phone charger/holder permanently on standby, with its bright green LED showing (I know, but the feed I used was not switched as I suspected, which I elected to leave in place as it was getting dark by the time I noticed....).
I went to start it yesterday and it was VERY sluggish indeed, although it did fire up on both cylinders eventually. What followed was broadly OK running for about 30 seconds, followed by the dreaded "Stop/Start Unavailable" message, the Yellow Warning Triangle showing on the centre display and also the Engine Light burning brightly in front of me. Suspecting just the usual low voltage issue, I drove on expecting it sort sort itself out. However, 400m later the engine dropped a cylinder and became very sick indeed - Pandas really don't go well on a single cylinder.....
I switched off, removed key, opened and closed the drivers door and locked the car. Unlocked it and started it up and we had 2 cylinders running again, but the Stop/Start button light was showing, as well as the Yellow Triangle. Anyway, I drove to where I had to go and car was fine (only about 10 mins away). Restarted after dropping stuff off and when I got home I used my new, recently acquired ELM327 WiFi OBD transmitter and the excellent iOS version of MULTIECUSCAN software that I'd installed on my iPhone8.
4 important faults logged - 2x Cylinder Failure messages and 2x Generic Systems Fault messages - no mention of Low Voltage however. I cleared them both, checked the alternator output (soooo easy to use, log and monitor - excellent work MULTIECUSCAN peoples...!) and could see that it was pushing 14.1v at 2000rpm and that dropped to about 13.4 with the Heated Screens switched on. So all OK from a technical perspective. Cleared the faults and put the battery on a C-TEK conditioner/charger and left it over night. Good as gold this morning.
So, moral of this story is that the condition of the startup voltage available at the battery is absolutely critical for good running of your Pandas and 500's. In the olden days, all a flat battery needed was a jump start and everything was fine - so not the case with these new-fangled modern systems whatsoever. I am considering replacing the now 6 year old battery, although that is a little premature in my view, so I will see how things go with the C-TEK in place for the duration of the continued lockdown and then when we're released back into the wild in due course. New 60Ah / 550CCA batteries are over £120 typically, so let's not rush into buying something that isn't necessarily needed right now.
So there you have it, conclusive proof that what we already knew to be the cause, definitely is!
Interesting post R1NGA, thanks very much.
Our 2012 Panda Dynamic Eco doesn't have much in the way of the modern "bells and whistles" (like stop/start etc), so I feel confident putting the battery charger on her for an overnight session once a week which keeps her in tip top condition.
I bought the Ibiza new and, apart from the well known turbo wastegate problem (new, modified turbo under warranty) it's really worked well. However just recently, for the last couple of months, It's come up with stop/start not working for the first couple of miles after a cold start. I'm a retired person so the usage has not changed much due to the virus lockdown. Often stands for 2 or 3 days without starting but then, typically, will do a 20 mile journey, I don't do "trips to the shops" with it (only done 18,000 miles in about 4.5 years). The battery is one of these "fancy" enhanced flooded battery types and quite expensive to renew so I'm not planning on doing anything rash but I do feel that putting the battery charger (CTEC Multi XS 7000) on now and again would be a good idea. I'm thinking that this may be an early indication of age in the battery.
However - and I've asked this question in a number of places, so apologies if you've come across it before - the Ibiza has battery sensing electronics which I believe can be damaged if you connect a jump battery directly to the battery terminals. I believe the sensing module is on the earth side, and I see a very strict instruction in the owner's handbook to only connect a jump battery + to + and - on the jump battery to engine block on the car (I've done this for years anyway to avoid sparks igniting battery gasses but now it would seem to be being recommended to avoid damage to the module.
So I'm thinking maybe the charger should be connected in the same way? What do you think folks?
Thanks for the full story :)
Twinairs use so much tech to go 'phut..phut' ;)
Its small wonder it ran sick.. :eek:
That battery price seems very high though
Seem to recall werdna payed @50% of that
Charlie .
My TA punto is on its 2012 factory battery covered 52 k but only used for trips @1 week in 4.. probably kill it now though.. :eek:
I am sure that the advice for jump-starting is very well placed - shock loads and peak current and voltage spikes can be huge when 500+ amps of incorrectly connected battery terminals are concerned, so I too avoid jumping from car to car and indeed carry one of those small LiPo packet jumpers that work remarkably well.
The C-TEKs are very good and maintain batteries in a much more gentle way. Right now it's simply connected to the battery terminals and I doubt it will cause a problem, as they are designed for modern vehicles. I may be proven wrong, but for now the proper voltage in the battery itself is paying dividends that overshadow any electronics concern at this moment :)
Oh - how long has MES been available for iOS? As a Mac user I looked early on when I got the 2013 Panda and saw it was Windows only and have never looked back :). I’ll go and explore.
Edit: I have explored and see three reviews in past three months, all of whom say iit doesn’t work. What they don’t say is how new/old their cars are — did I read somewhere else MES may not fully function on the very latest Fiat models?
I think it's only the 500x that has the SGW module allthough I expect the new hybrid 500 will have this
Interesting post R1NGA.... However - and I've asked this question in a number of places, so apologies if you've come across it before - the Ibiza has battery sensing electronics which I believe can be damaged if you connect a jump battery directly to the battery terminals. I believe the sensing module is on the earth side, and I see a very strict instruction in the owner's handbook to only connect a jump battery + to + and - on the jump battery to engine block on the car (I've done this for years anyway to avoid sparks igniting battery gasses but now it would seem to be being recommended to avoid damage to the module.
The instruction book for the Panda show this:
Release the quick-release connector on the negative lead where it joins the voltage sensor connected to the battery. Note though that this leaves the voltage sensor in place, clamped direct onto the battery negative post. Connect the battery charger to the metal part the quick-release unclipped from (part marked D in the diagrams). That way, the system is aware that the battery is being charged -as it would be with the alternator charging it. (See photo of manual page). I would expect similar advice for your Ibiza.
The advice to not connect jump leads is more (entirely?) to prevent any spark igniting hydrogen gas released from the battery - there being a suggestion that more is released from a struggling, under-charged unit.
Thanks Pete - seems odd to disconnect the rest of the electrical systems when trickle charging, but maybe there's concern for some other delicate componentry somewhere. The end result is the same I guess.
iOS version of MES has been around for a while but I'd not taken the plunge until I read about v1.5 being announced on the MES site - it's now up to v1.7 and also supports iPAD too. Looks like they're investing time and effort in it now, so that bodes well. https://www.multiecuscan.net
I took a bit of a plunge with the ELM327 WiFi adapter as there are quite a few on the market, but the thing arrived, is small and neat (about the size of a cigarette packet) and I can have it in the car all the time when out and about. This is the ELM unit I bought;
https://www.amazon.co.uk/gp/product/B0721DC46Y/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Seems to work well. Only issue is that the Licence for iOS MES is another £50, so you need to be keen. But I am very please with the purchase so far. :)
Folks,
Can anyone explain, why would it run on only one cylinder because of a old battery? I have the start / stop light on mine - I am going to try a new battery.
This is interesting, our 2014 TA Trekking has been exhibiting some weird things since the weekend. The Stop start just works when it feels like it. The TPMS flashed up showing check tyre pressures whilst my wife was on the way to work. She checked it over at work, all tyres correct pressure, she reset it and all OK. Today the BlueandMe activated itself whilst she was driving asking to connect or cancel, we have never paired it with anything. Again canceled so will await the next oddity. It is on its original battery. Gets driven 40 miles a day every other week when she is on shift it then has a week of little or no driving. Will connect up my ctek charger and see if it makes a difference.
Hi RINGA. I got very hung up over the possibility of doing damage to my 2016 Ibiza by charging the battery, especially with regard to the battery condition monitoring device on the negative terminal.
It all came to a head when I hadn't used the car for some time because of the lock down and I noticed the static battery voltage was down a little and the stop start - which I tend to disable at every start up - was coming up unavailable so I wanted to connect the charger (it's a ctek multi XS 7000) to boost the battery back up without damaging anything.
I had a number of very interesting communications with both SEAT and Ctek. Ctek in particular were very helpful and informative - they've left me with a very positive impression of their company.
Most of the info came up in this, quite lengthy, thread: https://www.fiatforum.com/leisure-lounge/480670-electronic-battery-sensors.html. If you didn't read it at the time you may find something of use to you in it?
All the best
Jock
I changed the battery, filters and spark plugs - and I still get the start stop triangle - and I have the running on one cylinder problem. Any suggestions?
I think we blame low voltage too quickly. Remember once started the system volts will rise as the alternator is charging the battery. Once started the voltage should rise rapidly to 14.4v and above initially till the battery is charged then it should stabilise between 13.8 and 14.4v.
Hi :)
More info please ;)
Thats several issues.. and potentially 20 fixes. :)
How long on old plugs..
What oil is in it.. were the serice items reset correctly on last change.. how long ago?
Our 2013 ta
Sounded very laboured yesterday on starting
(to the point where our old 1108cc 169 would zero its clock..)
It ran on both cylinders.no warnings.. clock was fine
Car was used the day before..another short trip :eek:
I will give it the 110 mile each way treatment in the week
Ive no idea on the batterys health
Purchased car last summer and did a 17 mile commute for the 9 months until covid
Will update later this week :)
Hi :)
More info please ;)
Old plugs ran over 100.000 km -
I don't no what you mean with " the serice items reset correctly on last change" - it was done by a mechanic.
The oil is SAE 0W-30 ACEA C2 /*API SN
Plugs on a twinair have a hard life my punto had 4 sets in that distance..
So a chance they have stressed the electronics driving the sparks (a common issue in the FIRE motored punto)
I have no idea if the mechanic has been changing both oil filters.. or even checking the small one..
So cannot really say if the function of the uniair could be partly to blame.
If these were the only issues.. it would be time to perform sniffer tests..a compression ..or leak down test
But there is a chance that its an electrical problem causing it.
Badly worn plugs can cause the coil or coils to break down.
It's simple really why this can happen. Say for example a new plug has a 1mm gap and needs 10kv to fire the plug as it wears to 2mm it then requires say 20kv that extra 10kv can flash across another path, between leads and the internal insulation of the coil or coils. Manufacturers make recommendations for a reason and they know best. If you want long lived plugs then fit platinum ones, I'd not leave a standard plug in for more than 15000 miles.
