- Dec 16, 2019
- 25
- 7
Has anyone put steel wheels on their Cross - if so what did you use -I’m waiting for Fiat technical to confirm what they recommend
Check the handbook it should be listed thereHas anyone put steel wheels on their Cross - if so what did you use -I’m waiting for Fiat technical to confirm what they recommend
Why would you want to? The standard wheels on the Cross (the 'real' 4x4 Cross, not the various City Cross variants) are rust-resisting alloy (rather than rust-attracting steel), and come from the factory with all season tyres that have the symbol on them meaning the are accepted as true snow tyres in countries that need them by law (eg the Alps in Winter). And the 'approved' wheels for the Cross (steel or alloy) are all the same size, as shown in the list from the handbook in the previous post above)Has anyone put steel wheels on their Cross - if so what did you use -I’m waiting for Fiat technical to confirm what they recommend
I could understand the question if swapping from summer tyres to winter ones and preferring to use two sets of wheels rather than changing the tyres between rims.
I didn’t go anywhere near a price list when I bought it - who does? I just asked for the best price. It’s not unrealistic to expect the car configurator to give the correct spec is it? What’s the point of a 4x4 with summer tyres? I do a good deal of country sports and wanted the car for its off-road capability. It’s a cracking car other than the current tyresAh ha - that would explain it! Good luck on that quest. The U.K. price list has clearly stated ‘summer tyres’ for some time now, even though the website says otherwise.
Summer tyres not great in wet mud. The 'all seasons' of the Cross will be better, and the full 'winters' of the regular 4x4 the best (the tyres on the 4x4 are called CrossContact winter - a winter-grade SUV semi off-road tyre and are great in thick mud)Mine new on the 5th had summer tyres as expected. Was at same dealer yesterday (14th) and there was same car (4x4 Cross) awaiting handover with All Season tyres, Goodyear Vectors. That said so far the summers on mine have been good off road.
Have just put a set of Michelin Alpins on my Waze 4x4 and swapped the summer tyres onto alloy wheels. Subjectively I would say the Michelin tyres are superior to the Continentals on my previous 4x4 although not tried in snow yet.
If you have a Cross I would check the engine is actually a 90HP as since 2018 I believe the 90HP was not used by Fiat. This they have finally more or less admitted in writing and issued an apology. Should it be the case on your car as on mine do as I did and let Fiat provide the wheels you require in compensation for their 'mistake'..... FOC.
Up to now I’ve not bothered with the engine capacity , as I was expecting to receive an 85hp - but based on a previous comment which advised that the price list was the definitive spec, I went and had a look at the Oct 2019 price list- Guess what - it shows the Cross 4x4 as a 90hp. Based on the engine serial number it’s a 85hp. One more issue for Customer Service
I think the press release referring to 90hp was OK - the 'true' Cross model was sold with a 90hp petrol when introduced, when all the other TAs were 85, and also it could be had 95hp diesel when others only had 90. But to continue to claim that after it changed (in July-ish 2018?) was clearly not right.They claim the oversight is due to human error, and was entirely a mistake in advertising. The fact that they issued at least one very detailed press release, stating its 90HP and told the 4x4 magazine that gave the 90HP Panda Cross its top award in its price bracket ...
To be fair, most car manufactures' websites have inaccuracies – the joys of international businesses having models with different specs for different markets, and specs which change frequently too.... As HertsHillHopper has pointed out on many occasions their information is often inaccurate on every level.
