Technical Another door problem
Tollbar6
Hi all,
First post here. My wife has a 2014 Panda Lounge and the nearside passenger rear door will not unlock. The central locking operates on the other 3 doors.
The child lock on this door is on and it could be opened from the outside, but not anymore. I managed to remove the door panel and checked that all cables are in place. I can operate the latches from inside the door, but no joy.
Using a mirror, I can see that the electrical connection for the C/L plugs on to the top of the assembly. I'm not sure how to remove that, or if it will make any difference if I do.
Can anyone advise how I'm going to get this door open?
thanks. Andy.
Hi. :)
Certainly not a common issue.. but there have been a few rear door issues on here.
SEARCH on here is pretty good.. you can do panda only.. which helps. ;)
Good luck.. :)
a good prompt for me to check our used panda has no child locks switched :)
Charlie
