Old 08-11-2019   #1
Failed Master Clutch Cylinder
My 8 month old Panda Cross is with Fiat at the moment having the master cylinder replaced, very disconcerting yesterday when the clutch pedal wouldn't rise back when changing gear.
Any others had a similar problem on such a new vehicle? I heard rumours that it is a known 500 fault.
markwo is offline Reply With Quote Quote
Old 08-11-2019   #2
Re: Failed Master Clutch Cylinder
@The Panda Nut may have had one.
Al D is offline Reply With Quote Quote
Old 08-11-2019   #3
Trader Rating: 1
The Panda Nut has donated!
Quote Originally Posted by markwo View Post
Al is right mine was at a similar age. The return spring is inside the cyliner and apparently is not the most reliable. I had the car for some time after and had no repetition, It was replaced in less than 2 hours under warranty. It worked sometimes and not others and then worked but felt wrong. Dealer identified and agrees the issue no trouble. I am watching the new car as I now dont trust this part... Thats only got to 3800 miles so far.
Noop now known as Nooplebe (i.e. in the way wherever he goes) 🐼
The Panda Nut is offline Reply With Quote Quote
(T) Grande punto master clutch cylinder/slave cylinder Ramrodd Grande Punto 0 31-07-2013 17:43
clutch master cylinder jim griggs Newbie Central 1 10-10-2011 16:37
(T) Clutch master cylinder Ocarru Multipla 1 19-06-2010 23:44
(T) Clutch master cylinder (Clutch not seperating properly) 57mmStroke Multipla 4 15-06-2008 21:22
(T) Master Cylinder (Clutch) ChristieCruiser Bravo / Brava 7 06-12-2007 15:49
