Old 10-09-2019   #1
KPat has donated!
Scary oil change.
Well I wouldn't take my Panda here for a service.
Oil changed to 10W 30. A dash of snake oil in the engine and gearbox. Then rev the cahoonas off it
Likes Saxon78 liked this post
KPat is offline Reply With Quote Quote
Old 10-09-2019   #2
''LUIGI''
2668GRIFFIN's Avatar
2668GRIFFIN has donated!
Re: Scary oil change.
What???????
Not sure what the issue is with oil change....looks ok to me
LUIGI
Likes murphyv310 liked this post
2668GRIFFIN is offline Reply With Quote Quote
Old 10-09-2019   #3
Trader Rating: 1
portland_bill has donated!
The stuff they put in the gearbox said 'power steering' on the label.
Likes The Panda Nut liked this post
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
Old 11-09-2019   #4
''LUIGI''
it says manual to me
LUIGI
Old 11-09-2019   #5
''LUIGI''
engine oil additive
Old 11-09-2019   #6
2017 Panda City Cross
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Hi.
Adding a friction reducing additive is not a good idea on a new engine. Although rings these days are reasonably bedded in they still need time to properly bed in. The addition of a friction reducing additive will slow this down and can lead to glazed bores. So no additives for the first 3000 miles. The increase in alleged power may be a con in my opinion.
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 15-09-2019   #7
France
Quote Originally Posted by KPat View Post
...instead of the recommended 5w40 C3.
10w is less fluid than 5w at cold startup.
-30 is thinner than -40 at operating temps (100C)
So less engine wear protection in both cold and hot
Of course, using a more fluid grade (-30 instead of -40 weight) will liberate some power in a pre race qualifying lap ( that explains the dyno results)...but will probably wreck an engine in a long race.
For a street car, sticking to the manufacturer's demand (5w-40 C3) is a bare minimum for engine protection.
Moreover, I don't even think that those modern engines benefit from more Zn like older ones, there are new metal protection layers lately, and new oil additives to match them (probably tungsten based, like Vanlube W324), that's why they recommend ACEA C3.
That nano additive-stuff, if Tungsten based, might not be so bad, but not in a new , running in engine.
An engine oil is a fragile balance, adding other stuff is not always a good ideea.
2008 Fiat Panda mk2 1.1
2013 Fiat Panda mk3 1.2
2014 Alfa Romeo Giulietta 1.4 MultiAir
Saxon78 is offline Reply With Quote Quote
Old 15-09-2019   #8
Moderator
g8rpi's Avatar
g8rpi has donated!
Using any oil additive or even an oil that does not meet the specification for the engine will invalidate any warranty. This includes aftermarket warranties as well as new car one. Oil additives can also adversely affect catalytic converters and other emissions equipment. This won't happen instantly but any damge is irreversable. Additives or wrong oil may also invalidate lease type arragements and lead to penalty payments.
The makers of these additives will not pay for any damage and you-tubers will not come back and say it didn't work long term.
Robert G8RPI.
Likes The Panda Nut, portland_bill liked this post
g8rpi is offline Reply With Quote Quote
Old 15-09-2019   #9
Trader Rating: 1
The oil manufacturers spend a lot of time and money in research. If the additives in that simple bottle were beneficial, and not reduce the efectiveness of the rest, surely they'd be in the oil already.
Old 15-09-2019   #10
Trader Rating: 1
The Panda Nut has donated!
Quote Originally Posted by portland_bill View Post
I agree. I had a long conversation with the GEM Motor assist technical officer and he totally convinced me of the need to stick with the manufacturers recommendations and that these days oils are often made for specific engines to counter individual characteristics of particular engines. I would perhaps recommend gear box oil additives for older gearboxes but I am not certain these are totally good in normal circumstances.
Noop now known as Nooplebe (i.e. in the way wherever he goes) 🐼
The Panda Nut is offline Reply With Quote Quote
(T) change engine oil message and red oil light flashing on the dash... grungdog23 500 34 05-03-2020 18:09
(T) Change Engine Oil Message & Flashing Red Oil Can Light stuartinlancashire Fiorino (Mk3) 14 05-10-2018 18:16
Gearbox change oil pouring out... Engine oil.... Punto jtd dubsential Tech Talk 0 15-06-2017 16:49
(T) Engine Oil change indicator wont stop after oil change! arbervehbi Croma 8 17-09-2015 20:34
(T) Fiat Ulysse leaking oil through crank shaft oil seal - how do I change them? *welsh.wizard* Ulysse 2 27-10-2012 00:08
