Now that I’ve got a new Panda and it’s more realistic to assume it’ll last for another 10 years, it’s finally not a bad idea to invest in winter tyres. Though other than looking for good tyres, I’ll also assumably need four new steel wheels of the right spec.
Where can I get good steels?
Also, might as well get a fifth for a spare too.
I was planning on using KwikFit if I were to order tyres via them, assuming I tell them I want my wheel trims to be unharmed and can literally watch through the viewing window as they do it!
Do you need to store the unused set of tyres anywhere special, or is garden shed in the shade good enough?
What sort of winter tyres do you recommend and why?
For summers I plan on using the factory Good years and buying the same each time renewal comes around. I’m convinced it’s worth having a set despite the fact we never get snow due to the temperature and the days and days of wet roads and the difference that makes.
How often do your winter tyres tend to last and when is right to switch over?
