Thread Tools
Old 01-05-2019   #1
Power loss and flashing engine management light - 1.2l Easy
The engine management light flashes and there is a dramatic loss in power when around 2nd/3rd. After initially thinking it was a dodgy fuel issue and replacing the spark plugs it's still happening. No code was stored, either. Any idea what my next move should be? I was thinking about replacing the HT leads?
Cheers,
Jonny
ronnyjock is offline Reply With Quote Quote
Old 01-05-2019   #2
Re: Power loss and flashing engine management light - 1.2l Easy
If it is ignition related then an intermittent misfire won't always set a code. I would start by changing the HT leads. If that doesn't do it then it could be a failing coil pack. They are around 100 to replace. But you can check if it is working ok with some of these:
https://www.halfords.com/workshop-to...n-spark-tester
KPat is offline Reply With Quote Quote
Thread Tools
Engine management light flashing John_boy17 (FS) Technical, help & guides 18 24-12-2017 23:00
(T) Engine management light flashing lersxt Cinquecento / Seicento 9 22-07-2015 19:35
(T) engine management light and loss of power. richie9870 Bravo / Brava 1 08-02-2011 11:14
(T) Loss of power, flashing engine light Kalby Punto (Mk2/2b) 7 03-11-2010 12:56
(T) Engine Management Warning Light-engine loss of power/cutout Loobylou Doblo 10 27-09-2010 12:00
