Thread Tools
Old 27-04-2019   #1
AAB1992 has donated!
Dash rattle
Sorry I know this topic has been covered before but Iíve got 68 pop with 8k thatís rattling badly when cold from the passenger side. It sounds like something plasticky that is affected by vibrations. Once warm it stops or if you press lightly on the dash top. Still a massive irritation, give how many years this has gone on for, you would have thought Fiat could have implemented a fix at the factory.
Anyway Iíve tried the usual, tightened the bolts for the airbag unit and had a good poke around with the glove box out. I canít find anything. Still rattles. Having read the previous posts, some people have issues with it when warm, mines goes away when warm. I canít be bothered talking it to the dealership, my previous panda was made worse after the ďdash fixĒ.
Will the 4mm rubber wedges work for this cold rattle from experience?
Adam
AAB1992 is offline Reply With Quote Quote
Old 28-04-2019   #2
Re: Dash rattle
i put some stick back door seal in between the dash and the a pillar, also when you have the glove box out look up under the dash and there's a large metal which runs under the top of the dash, i believe this is where the drumming comes from.
Leroypanda is offline Reply With Quote Quote
Old 07-06-2019   #3
Re: Dash rattle
Did you get it fixed i have same problem on a 4 months old panda it seems coming from glovebox but its not
nobrakes is offline Reply With Quote Quote
Old 08-06-2019   #4
They all do it . No fix , I've tried everything. My theory is that Fiat factory is warm and when the cars are shipped to colder climate nothing fits together , if you move to Italy yer car will be fine 😄😄
Likes The Panda Nut liked this post
Scott1968 is offline Reply With Quote Quote
Old 10-06-2019   #5
Re: Dash rattle
Quote Originally Posted by nobrakes View Post
I took it to the dealership back in April I think, when it was cooler. It rattled badly then. Surprise surprise when the garage had it, they couldnít hear it
Since then itís been quiet due to the warmer weather. To me it sounds like the centre vents or pipework being the dash. Any light pressure on the front of the dash stops the rattle. So Iím going to try wedging some foam between the centre vents and dash later in the year. Iíll see if that applies just enough pressure to stop the rattle. It wonít let me attach a video with noise
Old 10-06-2019   #6
Re: Dash rattle
This weekend we had a heatwave and all rattle stopped !
Old 10-06-2019   #7
Netherlands
Re: Dash rattle
Thanks for Global Warming
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 11-06-2019   #8
Trader Rating: 1
The Panda Nut has donated!
Re: Dash rattle
Quote Originally Posted by Scott1968 View Post
They all do it . No fix , I've tried everything. My theory is that Fiat factory is warm and when the cars are shipped to colder climate nothing fits together , if you move to Italy yer car will be fine ����
I am on my second new one since 2017 and touch wood have absolutely no rattles and squeaks. I have had many other makes that do this and have found that silicon spray in and around all joints like the windscreen demist vent and round the edge gives a fix but you must repeat every few months and make sure to wipe away any excess to avoid tide marks. Halfords sell this in yellow topped cans in the lubricants section. Worst culprit was a Golf, but the spray kept it firmly in check.
Noop now known as Nooplebe (i.e. in the way wherever he goes) 🐼
The Panda Nut is offline Reply With Quote Quote
Thread Tools
(T) dash rattle Leroypanda Panda (2012+) 10 25-10-2018 20:34
(G) Dash rattle eyebee Panda (2012+) 37 18-10-2017 19:07
Rattle in dash somewhere!! imported_Mechelle (FS) Car Chat 7 08-12-2004 17:41
(S) rattle in dash seank8 Stilo 2 25-09-2003 23:12
(S) rattle on dash seank8 Stilo 3 20-03-2003 18:24
