Old 18-04-2019   #1
Il Karro has donated!
Panda 4x4 Antarctica very low miles, some queries
Hi
got myself a Panda Antarctica in February a '14 plate, it has only done 3500 miles. Been doing some research on this site and have a list of things to get done.
No spare wheel only can of repair stuff, so looking to get a spare, still not sure if I should get space saver or source an alloy and get full size spare although I know it won't fit in boot, on the lookout for a doblo jack kit too.
Brakes are making a noise and can see from reading posts on here that this is a problem with the 4x4. Understand that the caliper dampers help eliminate the noise but doesn't really eliminate the underlying problem. Because the car wasn't used very much maybe the brakes have suffered.
I am considering replacing all pads, discs and calipers with pagid parts, my question is would this resolve the issue for good?
Any info, suggestions would be much appreciated.
Likes The Pretender liked this post
Il Karro is offline Reply With Quote Quote
Old 18-04-2019   #2
Re: Panda 4x4 Antarctica very low miles, some queries
Welcome. This thread may help. Also major service may help. Bits (oil and filter, pollen, air and plugs) probably around 110 and maybe same in labour (all in) to do if you're not handy yourself.
https://www.fiatforum.com/panda-iii/...1=#post4141920
Al D is offline Reply With Quote Quote
Old 18-04-2019   #3
Thanks for that will have a read of that thread now.
Old 18-04-2019   #4
Had read the info in this thread before and there are another few on the same topics. That is where the mention of the damper eliminating the noise but not the problem that causes the noise.
Old 19-04-2019   #5
This thread (that you've prob come across) has a part number for the suspension noise damping kit. I believe it's 200 to have it done. I had brakes cleaned around a year ago and noise hasn't returned. Can have brakes cleaned on my TA 4x4 4 times for the above cost.
https://www.fiatforum.com/panda-iii/...-brakes-4.html
Old 19-04-2019   #6
varesecrazy has donated!
Quote Originally Posted by Il Karro View Post
Hi
Hi. And welcome
Sounds like a great find.
Zero point changing discs..
They are currently 'better than new'
Agreed that it is a sticking issue..
Strip and clean the pads.. then reassemble to ensure there is no drag.
Whittling down SOME of the paint on the pad backing plate might just help.
Letting it move a little easier.
Charlie
Old 19-04-2019   #7
H...mention of the damper eliminating the noise but not the problem that causes the noise.
The problem is that when the discs are rotated 'backwards' with the brakes lightly applied, a vibration is set up between the fixed and the moving parts of the caliper which makes a sound as it sets up the resonant frequency of the system - a little bit like playing a tune on the rim of a wine glass. The damper adds weight which alters the natural resonant frequency of the system so using the brakes can no longer reach the resonant frequency. The issue affects all the 4x4 Pandas and used to affect the old Panda 100HP too, which used the same rear brakes.
On my 2013 4x43 (which I have since replaced), I had this issue but found that giving the calipers a good squirt with the jet of the hose when washing that car actually would 'cure' the problem for several days (suggesting that a build up of brake dust added to the equation). Eventually, when I replaced the pads at about 30,000 miles (by this time they were heading for 3/4 worn), the new pads I bought had a thin almost rubber-like backing pad on them. Using these solved the problem for the rest of the time I had the car. Personally, I don't like using greases etc on the sliding parts of the calipers and pad mounts as these cause the brake dust to stick and gum up the bits that are supposed to move easily (most car makers build the brakes 'dry' these days for this reason), but a little on the back of the pad will reduce the tendency to make noises (This is not necessary on pads which have a rubberised back or a spring on the back that fits into the calliper piston as those additions are there to prevent noise from being generated)
My new 4x4 had the damper kit already fitted (maybe done at the factory?) when I collected it in August 2018 with just 4miles on it. (built end May 2018, but bought by me as a pre-reg). Now with 11,000 miles on it, not a sound from the rear brakes, so it does seem to work.
2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Old 19-04-2019   #8
...I am considering replacing all pads, discs and calipers...
Before thinking of trying to replace rear discs (which you might need to do in about 40-50,000 miles' time), had a look here: https://www.fiatforum.com/panda-iii/...ml#post4377889
For now, just clean, and if necessary, add a small amount of copper grease to backs of the pads (they are very, very easy to remove). The original Fiat pads and discs are very long-lasting - 30,000 miles minimum – so no need (or point) in changing anything for a fair while yet.
Likes The Panda Nut, varesecrazy liked this post
Old 19-04-2019   #9
Goudrons has donated!
When I had my Antarctica the rear brakes howled after a few months, reverse was worse.
I stripped them down, cleaned them and used some brake grease on the sliding pins. They were completely dry.
As these pins are under little rubber gaiters, they shouldn't attract too much dust.
I also filed a small chamfer to the back edge of pads, so it wasn't running the disc up to a straight edge on the pad while reversing.
That seemed to sort it as they were quiet for the next 3 and a half years.
I seem to be suffering the same again with my Abarth, the brake noise is horrendous, much worse than the Panda ever was, screeching, squealing and howling even if I just look at the brake pedal, forward or backward.
There's also a lot of brake dust coming off them, all four wheels get totally caked with the stuff in less than a week. It's so bad I thought they must be binding, but they aren't.
I guess they need a proper strip and clean.
Goudrons is offline Reply With Quote Quote
Old 19-04-2019   #10
I stripped my rear brakes earlier in the week, because they were screeching while driving along (although silent under braking). The pads were jammed in tight, and took some removing. I cleaned everything up, carefully filed the lip off the discs, copper-greased the back of the pads and the retaining mounts, and put everything back together ... and it's still wailing like a banshee.
Likes The Panda Nut liked this post
Barchetta LE (no 2468), 1998, Silver with Red Hood/Leather, Hardtop, Wind-stop, Novitec SS Exhaust
Panda Cross Twinair, 15 Reg, in glorious Yellow
Talbot-Matra Murena 2.2 (Prep 142), 1983, Aquamarine
gar074 is offline Reply With Quote Quote
Old 20-04-2019   #11
Really appreciate all your replies. Never removed brake pads before to replace or clean but would maybe give it a go if someone was able to show me what to do. I am in the West lothian area of Scotland is there anyone near that has an hour to spare, that could go through the steps with me. Looked at pictures and videos but not really confident. Don't have a problem paying a garage but would like to be able to fix it myself.
Old 20-04-2019   #12
@murphyv310 is an hour from you. Maybe PM him.
Old 20-04-2019   #13
Good idea.
A bit far from Edinburgh..
But somebody will be local to you. Charlie
Old 20-04-2019   #14
I have PM'd murphyv310 to see if he knows anyone nearer.
Old 20-04-2019   #15
2017 Panda City Cross
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Puggit old Jock comes to mind.
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
(G) Panda 4x4 Antarctica ordered - anyone else thinking of taking the plunge? DismasX Panda (2012+) 239 28-07-2017 06:38
Panda 2012+ 12/62 Panda TA 4x4 low miles Al D Auction Watch 0 12-01-2017 16:18
(G) Panda Sisley 4x4 - Queries? natureman Panda (Classic) 25 18-10-2008 08:27
(G) 1986 Panda 4x4 queries waddow Panda (Classic) 10 18-02-2004 19:18
