Thread Tools
Old 15-04-2019   #1
mastertontom has donated!
antifreeeze
what antifreeze for 2017 panda? help
mastertontom is offline Reply With Quote Quote
Old 15-04-2019   #2
Trader Rating: 1
The Panda Nut has donated!
Re: antifreeeze
I use anything thats the same colour with a current spec. I believe glycol free is the right stuff. After two years you should test to make sure its still effective (hydrometer) Most anti freeze products mix with all others, and it will say on the label. Manufacturers recommend changing the fluid around two years. Its good practice as corrosion inhibitors in new fluid may be worth the expense / mess of changing.
Noop now known as Nooplebe (i.e. in the way wherever he goes) 🐼
The Panda Nut is offline Reply With Quote Quote
Old 15-04-2019   #3
chris3234 has donated!
Re: antifreeeze
Quote Originally Posted by The Panda Nut View Post
actually with oat type coolant the red one used in most modern cars it had a lifespan of 5 year's
2 year's was for the older blue
chris3234 is offline Reply With Quote Quote
Old 15-04-2019   #4
Re: antifreeeze
The correct type is the OAT type usually coloured red. Different coloured anti freeze should not be mixed
Likes murphyv310 liked this post
KPat is offline Reply With Quote Quote
Old 15-04-2019   #5
2017 Panda City Cross
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Re: antifreeeze
Quote Originally Posted by KPat View Post
Absolutely correct. Mixing OAT with Blue or Green antifreeze can cause it to thicken. It was one of the problems in the Rover K engine when owners changed the anitfreeze or topped up with the wrong stuff without properly flushing the OAT out.
http://badges.fuelly.com/images/sig-uk/917112.png
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 15-04-2019   #6
Trader Rating: 1
Re: antifreeeze
Quote Originally Posted by chris3234 View Post
I check the fluid annually and on one car its now 6 years old and still provides protection down to -25 I think originally it was protected to even lower temps. Not living in the arctic circle though I think this should be enough. This bears out what you say. At this age however the fluid does look a bit sad which is why I change slightly more regularly than is necessary.
Old 16-04-2019   #7
murphyv310's Avatar
Re: antifreeeze
Hi.
Don't forget to use de-ionised water if you mix up your own coolant. Some of the chemicals and bacteria in tap water can do damage to the colling system too.
Thanks Motorcyclist Colin thanked for this post
Likes Pugglt Auld Jock liked this post
Cheers Trevor
Thread Tools
