It's been a while since I did our old Mk1 Panda Parade but I'm fairly sure they are metric 6mm bolts with a same threaded nut in each corner (so 4 nuts). The sump was very very rusty and when I replaced it I had thought I might need to replace all the nuts and bolts. When it came down to it though I was able to reuse most of them (I think I replaced half a dozen). I just bought normal bolts (actually, to be correct they are called set screws because they are threaded all the way down - bolts are only threaded for part of their length) and cut them to the length I needed. It was easy, they are only small diameter.
