im Axle Specialists
Thread Tools
Old 07-03-2019   #1
2016 Panda Trekking Rear Shocks
This is the second time the rear shocks have been found leaking (presuming they were indeed changed by the dealer first time around) so I wondered, if I end up having to replace them myself, are they all the same for the current generation Panda or will the Trekking have different ones?
Thanks, Jason
Jaseone is offline Reply With Quote Quote
Old 07-03-2019   #2
Re: 2016 Panda Trekking Rear Shocks
I suspect the Trekking will be different, as it has the higher ground clearance (like the 4x4)... but not the rear drive or added rear weight that brings, so likely to be different again to the 4x4 part.
edit: 11 different shock absorber part numbers listed here - depends on fuel, drive, van version etc! https://www.fiatdalys.lt/en/catalog/parts/443/5/5/2/33/0/0/CC0.9/CMBBZ/GDX/rear-suspension
for my 4x4 diesel its this one, apparently: 51 939 980 which is of course the most expensive. (if you go tot he home page of that website – which is the genuine Fiat parts listing, but in Latvia! – you can put in your VIN number and then it lists pars specific to your car https://www.fiatdalys.lt
2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Thread Tools
(G) REAR-END SHUNT: Panda 4x4 2016 AntPDC Panda (2012+) 13 06-01-2018 11:36
(T) Panda 100hp - replacing rear shocks - Instructions /Guide? HannsG Panda 9 06-02-2017 20:00
(G) Arrivederci Panda Pop & Trekking in 2016 PandaIan Panda (2012+) 10 07-05-2016 09:41
(T) Panda 4x4 rear shocks arcmet Panda 3 17-07-2010 16:03
