Thread Tools
Old 15-10-2018   #1
Error Code: PO244 Overboost Solenoid Valve
TA Panda 4x4 with 55k on the clock. Been suffering a slight hesitation under load and a few days ago the car went into Limp Mode on a stretch of motorway. Got the car home and got the ECU checked. Error code is as per thread title. Is the Solenoid valve the wastegate valve?
Any idea where I can replace the faulty part?
Seagulls is offline Reply With Quote Quote
Old 15-10-2018   #2
Goudrons has donated!
Re: Error Code: PO244 Overboost Solenoid Valve
I believe this is a fairly generic code relating to turbo boost control rather than the solenoid it's self (though that is still possible).
If it over boosts it can throw up this as the engine ECU "sees" data that is out of expected range and can't compute it, so you get a circuit/range/performance code.
So this might be related to the loose wastegate spindle on the turbo that owners have been reporting, if the wastegate is stuck open, it'll overboost when or very near wide open throttle.
There's at least one thread about it with this vid
Goudrons is offline Reply With Quote Quote
Old 15-10-2018   #3
Thanks, the video shows the spindle as loose. Is there a way to tighten the spindle?
Old 17-10-2018   #4
I think not, though I believe there should be a small clearance in it to allow for expansion due to heat.
Old 03-06-2019   #5
Did you get this problem sorted? I am experiencing similar problems with the same P0244 fault code.
doggydoctor is offline Reply With Quote Quote
Old 4 Weeks Ago   #6
Quote Originally Posted by doggydoctor View Post
No. Still getting symptoms sporadically. Car stutters to get in the power band. If I rag the arse off the twin air it works brilliantly but is not (no) good on part throttle in sixth. The multiair is working as is the turbo - but something is making the car go into limp mode. I had a similar thing with a TDi VW unit and replacing the boost solenoid worked - but that was only a 40 part. The Fiat Part is the thick end of 250!
Old 4 Weeks Ago   #7
Quote Originally Posted by Seagulls View Post
Sounds almost like what mine does. Mine just gets the engine management light to come in, but no limp mode, just down on power.
It is usually triggered on long uphills doing around 70mph.
Was thinking of getting a terra clean done to see if it would make a difference.
Old 4 Weeks Ago   #8
Not sure that a Terraclean would help with a faulty solenoid - although I'm happy to be corrected.
And just to be concise - my TA also lights up with engine and triangle warning lights "Check Engine - StopStart unavailable".
Power is right down (I call this Limp Mode). The power does come back once I can get the MultiAir to get into the power band (on the - non-existent - cam) in any gear.
I will have a look at the sticking wastegate and also try to see if any pipes are split.
Thread Tools
(T) waste gate solenoid-overboost valve?? cilli Multipla 3 2 Weeks Ago 12:44
(T) Is overboost solenoid noise normal? Yiiiiieeeeehaw Punto (Mk2/2b) 0 05-10-2015 11:43
fault code P0236 overboost valve daddygez Lets Talk FIAT 0 02-09-2010 20:25
(G) multi 115jtd 2004 turbo overboost error multiplied Multipla 1 24-05-2010 08:28
(T) Egr Valve (or overboost valve?) zipuk Stilo 19 29-08-2008 20:38
