![]() | #1 | ||
Posts: 207 Thanks: 12 Trader Rating: 0 ![]() | Battery
![]() | #2 |
Posts: 354 Thanks: 23 Trader Rating: 0 ![]() | Re: Battery Euro car parts have a lion battery for 83.99 ..use code weekend 37...I say a lion battery as my zafira cdti has one .it has been great all though winter.
__________________ Thanks Phil ![]() |
![]() | #3 | ||
Posts: 2,138 Thanks: 212 Trader Rating: 0 ![]() | Re: Battery My 4x4 TA is just over five years old and Stop/Start had stopped stopping (!) even after a lengthy main road trip (to Italy). So, a couple of weeks back, I decided the battery was probably a bit tired - changed the battery - first halt, Stop worked - since then, Stop hasn't worked at all.
![]() | #4 | ||
Posts: 18 Thanks: 2 Trader Rating: 0 ![]() | Re: Battery Same issue here, changed the battery for a eurocarparts Lion special and stop/start only worked once. Put it on charge overnight and it’s worked ever since, it probably lost quite a bit of charge in the time it was sitting on the shelf. It’s good practice to bench charge a new battery with a smart charger before putting it in the car anyway.
![]() | #5 |
Posts: 1,358 Thanks: 97 Trader Rating: 0 ![]() | Re: Battery I see on the Rover 75&ZT forum that Lion batteries are giving trouble on the bigger engines and diesels. Could be down to poor manufacturing.
__________________ Cheers Trevor ![]() |
![]() | #6 |
Posts: 354 Thanks: 23 Trader Rating: 0 ![]() | Re: Battery Mines been great over winter..but it does get used evey day.it like anything you pay your money and take your choice..you still get a 3 year warranty.
![]() | #7 |
![]() | Re: Battery ![]()
__________________ |
![]() | #8 | ||
Posts: 466 Thanks: 51 Trader Rating: 0 ![]() | Re: Battery Things to consider when selecting a battery for a start/stop equipped vehicle: Lead acid or calcium batteries simply don't pack the punch required for the SS system. They have good instant current but fail prematurely with quick cycles between charging and discharging. Lithium batteries are lighter and fare better to charging and discharging compared to traditional batteries, but don't do well with frequent high-amp discharges (namely, the Start part of start/stop) as it degrades the cells much quicker. Glass mat and 'enhanced' flood (acid) batteries are usually the best compromise, but can be quite costly due to them being relatively new and not gaining much traction over lithium. All in all, I'd say the costs of s/s in the long run far outweigh the fuel and environmental benefits of using it in the first place as having to prematurely replace a battery carries far greater environmental impact (and cost) than the few drops of fuel it saves at a stop light only after the car has warmed up in the first place. Edit: another side effect of start/stop for turbocharged vehicles is that the oil and water pump also stop when 'stopped', which places greater heat and wear on the turbo, especially in stop and go city traffic where airflow is minimal.
![]() | #9 |
Posts: 3,465 Thanks: 163 Trader Rating: 0 ![]() | Re: Battery Start-Stop have never worked on any of my 85 TA cars, and i don't care it don't. ![]()
__________________ There are Pretenders among us..... Geniuses with the ability to become anyone they want to be. Abarth 595 Turismo. (195 hp-305Nm) |
![]() | #10 |
Posts: 354 Thanks: 23 Trader Rating: 0 ![]() | Re: Battery Same on my TA LOUNGE..Its never worked..
![]() | #11 |
Posts: 2,632 Thanks: 223 Trader Rating: 0 ![]() | Re: Battery The Lion battery from Eurocarparts in my Barchetta only lasted 2 years. Never again.
__________________ Barchetta LE (no 2468), 1998, Silver with Red Hood/Leather, Hardtop, Wind-stop, Novitec SS Exhaust Panda Cross Twinair, 15 Reg, in glorious Yellow ![]() Talbot-Matra Murena 2.2 (Prep 142), 1983, Aquamarine |
![]() | #12 |
Posts: 1,358 Thanks: 97 Trader Rating: 0 ![]() | Re: Battery Things to consider when selecting a battery for a start/stop equipped vehicle: Lead acid or calcium batteries simply don't pack the punch required for the SS system. They have good instant current but fail prematurely with quick cycles between charging and discharging. Lithium batteries are lighter and fare better to charging and discharging compared to traditional batteries, but don't do well with frequent high-amp discharges (namely, the Start part of start/stop) as it degrades the cells much quicker. Glass mat and 'enhanced' flood (acid) batteries are usually the best compromise, but can be quite costly due to them being relatively new and not gaining much traction over lithium. All in all, I'd say the costs of s/s in the long run far outweigh the fuel and environmental benefits of using it in the first place as having to prematurely replace a battery carries far greater environmental impact (and cost) than the few drops of fuel it saves at a stop light only after the car has warmed up in the first place. Edit: another side effect of start/stop for turbocharged vehicles is that the oil and water pump also stop when 'stopped', which places greater heat and wear on the turbo, especially in stop and go city traffic where airflow is minimal. They are totally different technologies. Stop start is nonsense in my mind and just a ploy for emissions
__________________ Cheers Trevor ![]() Last edited by murphyv310; 05-08-2018 at 22:01. |
![]() | #13 | ||
Posts: 2,338 Thanks: 305 Trader Rating: 0 ![]() | Re: Battery It depends on how it's done. I think I've stated in the past Fiat's attempt is crude and cheap. It utilises the starter motor and battery like a normal start, with a sensors to protect the battery. It's basically self defeating, using battery power to restart that it then has to work the engine to put back in it before the next stop, which it rarely manages. This wouldn't be too much of a problem if it had the opportunity to recharge, but in city conditions of repeated stops and starts, the sensor calls time as it's not getting the time to recharge. You've probably nailed it on the head regarding emissions ploy. On the other hand, I've a Citroen E-HDi with stop start and it works perfectly as some development and cost has been spent. It works on a hybrid alternator and capacitors. As you brake to stop, the alternator charges the capacitors, not the battery. It actually kills the engine just before it rolls to a stop, which is a bit disconcerting to start with. It then uses this power stored in the capacitors to spin the alternator, not the starter motor to restart the engine. It's really has stored and used wasted energy to perform the restart, it's also saves the battery from repeatedly heavy hits on the starter motor so isn't constantly working to recharge the battery between stops, it's win win. It's pretty seamless and smooth, it never fails to stop once the temp gauge starts to move off the stop and restarts are instant when you foot leaves the brake pedal, so there's no pause as it restarts, it's started just in time without that awkward pause. Due to it stopping the engine before stopping, I wasn't a fan at first, but it's gown on me now and really is saving me fuel around town. At the moment I'm just over 3 mpg worse in to town than on a motorway run, my Panda TA was move like 16 or 17 mpg worse. Shame it's a Euro 5 and will soon be banned from the city centres!
![]() | #14 |
![]() | #15 |
Posts: 2,632 Thanks: 223 Trader Rating: 0 ![]() | Re: Battery Couldn't find the receipt. ![]()
![]() | Eireannbaker | Other Fiats | 3 | 10-11-2016 14:22 |
![]() | AlexanderDeLarge | Bravo | 2 | 16-09-2013 15:01 |
![]() | fruchty | Stilo | 9 | 28-04-2013 15:31 |
![]() | SmithSeicento | Cinquecento / Seicento | 0 | 30-08-2012 01:02 |
low battery flash when full battery?? | beau | Leisure Lounge | 6 | 10-11-2005 21:26 |
