Dr Zhivago
I have just replaced the water pump, and the job is a swine. Seems that cars are now designed with no regard to doing repairs, only with regard to assembling at the factory. Would a dealer workshop pull the engine out?
The pump is held on with four 10mm AF nuts that can only be reached by a socket through the spokes of the pulley wheel. Between that pulley wheel and a chassis member is a gap of only about 20mm, so no room for a ratchet handle. Fortunately I have an extensive tool set (more than most professional mechanics - I know, I've been one) and the only way I found to do it was to use a 3/8" drive 10mm AF socket (I think a 1/2" drive socket would have been too big to go in) on a very short extension that slightly protruded from the holes in the pulley wheel. In the drive end of that extension I put a 25mm length of ~3/8" square rod (from a door latch) held in by a blob of grease. I was then able (just) to turn this with a 3/8" AF open ended spanner at about an eighth of a turn at a time (ie flipping the spanner over between each movement).
All this has to be done from below with the OS wheel and arch linings etc removed. The socket/extension/rod assembly had to be put between the pulley spokes at the lowest point and the pulley then carefully turned to raise it to the actual nut positions, as there is only room to put it in at the lowest point. You cannot see the nuts (or much else) during all this, you are going entirely by feel. It took me about an hour just removing the four nuts, but I was a bit quicker replacing them.
That was after draining the water of course, for which there is no specific provision. You cannot easily reach the bottom rad hose (I never even identified it), and most of the hose clips are nasty crimp things (fast for factory assembly) that are hard or impossible to remove without damaging the hose (and destroying the clip of course). What I did was to remove the hose from the bottom end of the overflow tank (having syphoned it out first) and push a long 1/4" rubber tube down it to syphon as much more out as possible. I then bent to hose down towards a bowl on the floor to drain more out. This did take the level at least below the level of the pump.
The old pump was leaking past the static body seal; the running seal on the spindle seemed OK judging by the water stain pattern. Only did 12,000 miles.
