Hi. Probably coil pack.
Read the engine fault code..and use that to aid buying the correct parts.
It this a turbo version?
Charlie
could you please explain:" imply running on one cylinder only which render it pretty much undriveable"Surely coil pack would imply running on one cylinder only which render it pretty much undriveable? If it ticks over OK (no load) then I'd look for air leaks etc and hope its nothing to do with the uni-air module.
Good luck!
1.your numbers are correct
2.Fiat dealer is highly expensive-yes.(replacing the hose will cost more than 210 GBP)
3. what is:"the engine will probably run at tick over (no load, when not moving) ok"
4.shluld I ask them to check the coil pack?I told them (before they found the leak)
about the coil pack and they looked at me like I was talking nonsense...
thanks
Hi, the garage just told me, after checking, they found a crack in an air hose that deals with the air pressure in the turbo system(not sure myself if it is the exact term) and they will (costly) replace the hose and check if it helps. any advice?
the garage indeed replaced the rubber hose(f-500 0.9cc) attached with 2 metal bands.
I took a photo of the cracked one(can u see?). I hope it will work good.
there are very few panda TA here so they have little experience.
when the panda TA works good it drives(5 passenger) great .the question is:
when it will "fall" again ? and maybe I should have bought a regular 1.2 panda...
