Punto2012 New member Joined May 9, 2018 Messages 2 Points 1 Location Johannesburg May 9, 2018 #1 Hi there all. I have a 2012 Panda. My problem is that as I start moving and driving, there is a terrible rattling / scrapping noise from the left front side of the car. Why is this. Can anybody advise. Thanks.
puntofan01 Prominent member Parked in the garage Joined Mar 1, 2014 Messages 4,579 Points 828 May 9, 2018 #2 It could be a broken spring?
OP OP Punto2012 New member Joined May 9, 2018 Messages 2 Points 1 Location Johannesburg May 9, 2018 #3 Thank you for the reply. Will check it out.
M murphyv310 No Fiat now unfortunately Parked in the garage Joined Aug 19, 2010 Messages 1,616 Points 451 Location Kilmarnock May 9, 2018 #4 Worn pads, outer drive shaft, wheel bearings, stone stuck between caliper and disc, many possibilities
B babbo_umbro Established member Joined Oct 17, 2007 Messages 2,146 Points 468 Location Devon and Umbria May 10, 2018 #5 Does it also happen in reverse? What difference is there if you start on full steering lock?
