![]() | #1 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Gearbox going? My Twin Air Panda 4x4 on a 13 plate has been increasingly reluctant to change gear. Car's done 53000 miles and has been regularly maintained by an independent Fiat specialist Symptoms are: Difficulty engaging gears going up the box (under load) No real problem changing down the box (not under load) Harsh rattling/meshing noise over 3500 rpm in second gear Some intermittent vibration in the clutch pedal Clutch feels strong (no slipping) Car engages gears smoothly at idle with clutch depressed (no noises) Gear box engages fine with engine switched off I was losing some fluid from the reservoir so the master and slave cylinders have been replaced. Im thinking bearing in the box? Perhaps flywheel? Any suggestions?
![]() | #2 |
Posts: 1,356 Thanks: 97 Trader Rating: 0 ![]() | Re: Gearbox going? Has the gearbox oil level been checked? Does the noise appear if you press the clutch pedal with the engine idling or is it worse with the clutch up and idling?
__________________ Cheers Trevor ![]() |
![]() | #3 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Re: Gearbox going? I'm draining the box tomorrow to see if there's any debris in the oil.
![]() | #4 |
Posts: 1,356 Thanks: 97 Trader Rating: 0 ![]() | Re: Gearbox going? Good plan. The reason I asked about the clutch is that if there is a lit of noise on pressing the pedal its most likely to be the release bearing, if the noise is worse with the pedal up then gearbox input bearings. If at speed more likely a gear chipped, synchro or another bearing, of course the DMF (flywheel) is another possibility. Or even a driveshaft. Good luck though and I hope it's not going to be expensive.
__________________ Cheers Trevor ![]() Last edited by murphyv310; 24-04-2018 at 09:38. |
![]() | #5 |
Posts: 1,356 Thanks: 97 Trader Rating: 0 ![]() | Re: Gearbox going? Hi. I assume then the TA & MJ diesel have a DMF and the 1.2 a solid flywheel?
![]() | #6 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Re: Gearbox going? My Twin Air Panda 4x4 on a 13 plate has been increasingly reluctant to change gear. Car's done 53000 miles and has been regularly maintained by an independent Fiat specialist Symptoms are: Difficulty engaging gears going up the box (under load) No real problem changing down the box (not under load) Harsh rattling/meshing noise over 3500 rpm in second gear Some intermittent vibration in the clutch pedal Clutch feels strong (no slipping) Car engages gears smoothly at idle with clutch depressed (no noises) Gear box engages fine with engine switched off I was losing some fluid from the reservoir so the master and slave cylinders have been replaced. Im thinking bearing in the box? Perhaps flywheel? Any suggestions?
![]() | #7 | ||
Posts: 149 Thanks: 13 Trader Rating: 0 ![]() | Re: Gearbox going? In my recent experience (4x4 TA) DMF/clutch breakdown. Where does the clutch bite? Pedal near the floor?
![]() | #8 | ||
Posts: 149 Thanks: 13 Trader Rating: 0 ![]() | Re: Gearbox going? I'm glad you posted here as I have just had exactly the same symptom start today on my way home from work (30 mile hilly), 64 plate Panda Cross Twinair, nearly 40k miles on the clock. Is fine in all other gears and if drive through the rattle it settles down. Stalls under load with no clutch slip, the rattle is very obvious through the gear stick when in second between 3.5k and 4.5k RPM range.
![]() | #9 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Re: Gearbox going? Well mines been waiting at Stoneacre in Hyde since Saturday morning and they havent even looked at it yet, saying loads of breakdowns so wont be looked until end of week! Any news on yours?
![]() | #10 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Re: Gearbox going (Updated DMF Seized) Just an update. Got the gearbox away from the engine to reveal a distinctly seized/warped DMF. All fixed now with new clutch. The box is really sweet and the car feels appreciably quicker. Although I'm sure I can feel some sort of subtle engagement/disengagement in the drivetrain. But this might be the DMF actually working properly (I've only had the car for a year) or the 4 wheel drive system. I no longer get the ELD unavailable coming up on the dash intermittently. Just got to sort out the squeaking rear brakes now!!
![]() | #11 | ||
Posts: 149 Thanks: 13 Trader Rating: 0 ![]() | Re: Gearbox going (Updated DMF Seized) Just an update. Got the gearbox away from the engine to reveal a distinctly seized/warped DMF. All fixed now with new clutch. The box is really sweet and the car feels appreciably quicker. Although I'm sure I can feel some sort of subtle engagement/disengagement in the drivetrain. But this might be the DMF actually working properly (I've only had the car for a year) or the 4 wheel drive system. I no longer get the ELD unavailable coming up on the dash intermittently. Just got to sort out the squeaking rear brakes now!! It's that rattle through the gearstick that seems to be the clue of things going wrong with the DMF/clutch, although my experience was combined with the clutch "bite" heading towards the floor.
![]() | #12 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Re: Gearbox going (Updated DMF Seized) It really does feel a bit quicker!! I'm not sure the twin air will ever feel smooth but there is much less vibration now.
![]() | #13 |
Posts: 2,622 Thanks: 223 Trader Rating: 0 ![]() | Re: Gearbox going (Updated DMF Seized) How much did they charge you?
__________________ Barchetta LE (no 2468), 1998, Silver with Red Hood/Leather, Hardtop, Wind-stop, Novitec SS Exhaust Panda Cross Twinair, 15 Reg, in glorious Yellow ![]() Talbot-Matra Murena 2.2 (Prep 142), 1983, Aquamarine |
![]() | #14 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Re: Gearbox going (Updated DMF Seized) Local Fiat Specialist £633 including all parts.
![]() | #15 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Re: Gearbox going (Updated DMF Seized) Also, Stop Start works now for first time??? But will automatically start after 20-25 seconds. Love the car but it's a quirky little bugger.
![]() | drflaver | Multipla | 1 | 07-06-2012 18:48 |
![]() | dethleff | Ducato | 1 | 16-11-2010 15:34 |
![]() | usedtohaveavaldisere | Panda (Classic) | 6 | 13-03-2010 20:48 |
![]() | creep | Grande Punto | 1 | 10-03-2010 15:17 |
![]() | samsonite | Punto (Mk1) | 0 | 22-11-2009 15:15 |
