Thread Tools
Old 15-04-2018   #1
Gear lever
Hi, my panda 4x4 has developed a problem. When in neutral if I push the gear lever to the side it no longer springs back to the central position. The gearbox works great.
Any ideas.
Thanks. Anne.
landie9 is offline Reply With Quote Quote
Old 16-04-2018   #2
Turkey
Re: Gear lever
Two things I can think of are, the spring in the linkage that re-centers the lever is börked, or the linkage itself has become misaligned and needs to be re-centered.
oyumurtaci is offline Reply With Quote Quote
Old 17-04-2018   #3
chris3234 has donated!
Re: Gear lever
Probably the spring
Not familiar with the panda but if you remove the gaitor around the stick you you be able to see the return spring
chris3234 is offline Reply With Quote Quote
Old 17-04-2018   #4
Re: Gear lever
Probably the spring
Old 17-04-2018   #5
Re: Gear lever
Hi, checked spring and it's ok.
The problem seems to be at the gearbox end of the cable.
How do l remove the cable from the gearbox linkage?
Does the cable just pull off the linkage.
Anne.
Old 17-04-2018   #6
Re: Gear lever
Mine recently developed the same issue. I tried lubricating the cables etc, but then realised the problem was elsewhere...
On top of the gearbox itself, one of the 'levers' the cables connect to (the upper one, nearer the front of the car) is connected to a rod that passes through in a 'sleeve' cast into the top of the gearbox. I applied a little oil to either end of this and as if by magic everything became lovely and springy again.
I'll see if I can take a photo tomorrow, but its a hard place to see. To apply the oil, I used a kids paintbrush on the end of a bamboo cane, and carefully managed to put just a drip in the right place. It may also be reachable through the wheel arch after taking the wheel off.
Likes landie9 liked this post
2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Old 19-04-2018   #7
Re: Gear lever
Hi, thanks Hillhopper.
I removed the battery and battery box and was able to get to the gear linkage.
I put oil on the moving parts and let it soak overnight. Problem solved at no cost. The gear lever now self centres and feels normal.
Many thanks. Anne.
Thanks murphyv310, Herts Hillhopper thanked for this post
Likes jrkitching liked this post
Old 23-04-2018   #8
Re: Gear lever
Thanks for that - one of the most useful recent posts. Don't need the info - yet - but will bear it in mind.
Likes murphyv310 liked this post
babbo_umbro is offline Reply With Quote Quote
Thread Tools
(G) Gear lever 124spiderman Bravo 5 31-03-2017 10:49
(T) Odd gear selection problem/floppy gear lever on 1.2 8v? Taipan Punto (Mk2/2b) 15 20-01-2015 08:18
(T) 1.9 jtd Gear lever Heavy / hard to select gear boldy33 Punto (Mk2/2b) 2 27-05-2011 13:32
(T) Gear lever helicopter_red Cinquecento / Seicento 2 02-06-2004 07:00
